22 hours ago, Manges said:
Can regular ’paint thinner’ be used to thin the cement?
Barge cement thins nicely with Tanner's Bond cement thinner available at Tandy's.  Barge all purpose thinner behaves similarly.   I think both thinners contain toluene, heptane, and some ethyl acetate.  Toluene is available in hardware stores.  The other ingredients are harder to find.
I read on a reddit that the thinner is methyl ethyl ketone (MEK). I do not know if that is correct.
the SDS for both the cement and the thinner confirms the above.
No.  I know brands are different , but  I use toluene in my contact adhesive to thin it out . Don't need much,   approx a table spoon if the (500ml)  tin is still a bit full, or half full.  Or a few tea spoons to soften up the bits at the bottom  . I usually leave it over night for best results.
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
There's a rule of thumb I discovered a long time ago - the nastier the stuff is (to you) the better it works!!!!!:lol:
Toluene and Xylene are both very good thinners - but you don't want to make a habit of breathing them in.
Very true, worked with toluene in the fibreglass industry for many years, and it was also once used in the process of printing newspapers , was   part for that too once. It  can burn on contact with the skin.
And for those with sensitive skin, wear gloves & eye protection . :yes:
HS
