Contributing Member wolvenstien Posted May 7, 2008 Contributing Member Report Posted May 7, 2008 Ok, lets say I made a pair of shoes out of veg tan (including the outer sole), and used Fiebings antique on it. What would you suggest I use as a final finish before the shoes are worn? Quote
David Posted May 7, 2008 Report Posted May 7, 2008 Ok, lets say I made a pair of shoes out of veg tan (including the outer sole), and used Fiebings antique on it. What would you suggest I use as a final finish before the shoes are worn? Neat Lac is about the only product that I have found that will hold Fiebings antiquing paste where it belongs. David Theobald Quote
Members MadTailor Posted May 7, 2008 Members Report Posted May 7, 2008 Ok, lets say I made a pair of shoes out of veg tan (including the outer sole), and used Fiebings antique on it. What would you suggest I use as a final finish before the shoes are worn? Second what David says. Quote
Ambassador Luke Hatley Posted May 7, 2008 Ambassador Report Posted May 7, 2008 Ok, lets say I made a pair of shoes out of veg tan (including the outer sole), and used Fiebings antique on it. What would you suggest I use as a final finish before the shoes are worn? O K... Wolvie. IF, you did make a pair of shoes from veg tan leather, do you not think that they would be kinda stiff? would you not want them to be flexiable? Quote
Members skip Posted May 7, 2008 Members Report Posted May 7, 2008 How about a few pictures so we can see your fine work and see what the shoes look like. I agree with the neat lac, however I believe a nice leather dressing with some beeswax would probably help soften the leather a little, I use Skidmores saddle dressing, Aussie dressing works well also. good luck. Quote
Contributing Member wolvenstien Posted May 8, 2008 Author Contributing Member Report Posted May 8, 2008 No pix.... this is a PIF item.... they arent shoes.... but that was as close a description I could make staying close to what they are without giving away what they are.... once they are sent to CitzenKate pix will be posted.... NeetLac it is.... TG I still have a big can of it.... Quote
