Aligning Tandy's Small Alphabet Stamps
How do you alight properly a small alphabet stamps from Tandy?
Either I became prejudiced, or they really are misaligned on their squares... Pure guess work from my side.
Thanks.
Ellen;
Did you see the George Hurst demo on the Tandy site?
Thanks.
Nope, going there now. Thanks!
I used a ruler, as it usually recommended.
  • Ambassador
Thanks.
Ellen,
take some playdough, a ruler, and see how far off they are when you try a straight line-up. I have one that's crooked and marked it with a sharpie. I almost always carve letters but some folks want the small fonts and don't care about the stamped look. I bevel and spoon them anyway to get rid of the halo.
pete
They are NOT aligned on the stamps all the same way. I don't use a ruler. I stamp whatever is the middle letter of the word/phrase and work sideways from there. After I've stamped that first letter, I lightly tap the next one, take it off, see how it is, and go from there. Again, it's a matter of practice, and I also try to mark/remember which ones are way off.
Holly Moore
Wild Rose Creations
http://www.wrcleather.com
Anybody tried filing/grinding the sides of the stamps to correct the alignment?
I had to grind down the sides of one alphabet set I bought. It didn't look like they were finished during manufacture with lots of flashing left on all sides. I used a dremel with a metal grinding stone.
My stamps are square to withing 1/64" but there is a burr on some edges that should be cleaned up.
You might have better luck using a square or straight edge to place the stamps against, although I haven't tried it myself.
post-19342-019010800 1296848661_thumb.jp
I have a bunch of sets of letters from 1/4" up to 1" mine mostly line up right, but like Holly said I start in the middle and work out. Another thing that I consider is mine are all old, none newer that the mid 70's and most older. We all know that back then they made things better that today, so that is probably a factor as well. One last thing too is all the letters are not the same size, ex. the I is a lot smaller than the W. Anyway hope this helps some Billy P
Billy P        SideLine Leather Co.        Leatherworker.net/Forum
