Members Round Brim Hat Posted February 12, 2011 Members Report Posted February 12, 2011 So I purchased a saddle from a shop here in Alberta, it is a Texas Saddle Co. brand, built not to badly built. I did have to make a few modifications to it already. But after using it last summer a lot I noticed there are some hotspots that appear not matter which horse I put it one. The broader horses aren't as bad but the younger ones get heated up pretty good. The hotspots are right on the withers on each side and also at the rear of the tree just in front of the kidneys. Also when I pull the cinch tight the rear of the saddle lifts up a lot from the horses back. So I have so far torn into the under side of my saddle and have the bare tree to work with. Once it starts getting warmer and our horses lose the winter coat I'll fit the saddle and do the blocking as required. I'll try and post pics later. Kronic Quote
Members Round Brim Hat Posted February 21, 2011 Author Members Report Posted February 21, 2011 (edited) ]Here are some pics of the tree from the under side: At the front of the paddle on the bottom of the tree there is about a 1-1-1/2" spot where there is a high pressure/rub area. The white stuff is just baby powder from trying to keep the saddle a little quieter. Kronic Edited February 21, 2011 by Kronic Quote
Rod and Denise Nikkel Posted February 22, 2011 Report Posted February 22, 2011 Kronic, The two most common reasons a saddle will pull down in front and lift off the back when you cinch up are 1.) it is too wide at the front so it tips down and 2.) it has too much rock in it so cinching makes the front pull down. Having bars with no back stirrup grooves don't help here in either case. The stirrup leathers effectively add rock to the tree and they also can make a pivot point if the saddle is too wide. You can sure see the ridge in the skirts already from the back of the stirrup leathers. That has to be a pressure point. It is unusual to have a saddle soring in the back when it is pulling down in the front so much. Now that you have the skirts off, you will learn the most by putting the tree on the horse and seeing if you can correlate where the hot spots were to the part of the tree that contacts that area. For example, the problem areas at the rear of the tree - do they correspond to those strings coming through the bars? They look kind of lumpy in the pictures. Maybe you want to do the baby powder trick - put baby powder on the horse, place the tree on the horse, then lift off and check horse and tree for where the powder transfers. You know where the contact is that way. Be interested in knowing what you find out. Quote "Every tree maker does things differently." www.rodnikkel.com
Members Round Brim Hat Posted February 22, 2011 Author Members Report Posted February 22, 2011 Hi Rod and Denise I didn't know you were on here. I know a couple of guys that get trees from you and really like your work. The tree does have a cut out for the stirrup leathers, mind you it might not be enough. I don't think it would be the strings coming through, the area that is affected at the back is in front of this. I am going to take everything you mentioned into account and keep a close eye on those. I'm going to have to wait until the horses start loosing some winter hair though, with the cold winter we've had the coats are pretty thick right now. Kronic Quote
Rod and Denise Nikkel Posted February 22, 2011 Report Posted February 22, 2011 Kronic, please post what you find. Your situation doesn't fit "the norm". Usually when there are problem areas front and back it is due to bridging - not enough rock and only front and back contact. But then the back usually doesn't lift off when you cinch up. So those don't normally go together and make this a more interesting conundrum. The depth of the indentations in the skirts from those stirrup leathers with the little amount of wear on the rest of the saddle shows a problem as far as we are concerned. The back stirrup groove isn't deep enough to accomodate the stirrup leathers. That lump has, at minimum, changed the fit of the bars on the horses. Is that too far forward for the sore areas on your horses or might it be the cause? How far forward is this rigged relative to where the center of the front bar pad is? If the rigging pulls down too far forward it will pull the tips of the bars down onto the shoulders regardless of how well the bars match the shape of the horse, and this is worse if the tree is too wide or has lots of "flare" at the front. Again, this doesn't fit with soring farther back, but then this whole senario is unusual, making it likely you have a couple of things going on here, not just one (unless the back soreness is from the back of the stirrup leathers). Very interested in what you find out. Quote "Every tree maker does things differently." www.rodnikkel.com
Members Round Brim Hat Posted February 23, 2011 Author Members Report Posted February 23, 2011 With you saying that and looking again at the pictures it makes sense about the stirrup leathers, the indent on the skirts is very noticeable. When I fit this on the horses I'll try with stirrups in and with them out and see what kind of difference there is. The front rigging is right where the skirt has a half moon cut out on it, on the tree you can see where the rigging is still attached to the tree. Thanks for now though very helpful! Kronic Quote
Members GrampaJoel Posted February 23, 2011 Members Report Posted February 23, 2011 Wow, from looking at the skirts I can see that there could be a pivot point right at the stirrup leather . If the saddle tree is raised off the bars because the fender leathers where thicker than the bar cut outs. Could this be where the saddle is pivoting when cinched down tightly, causing the rear of the tree to rise up? Could be a bad pinch point also I would think. Just my thoughts. I'm not a saddle builder yet, but I have done some repairs. Joel Quote
Rod and Denise Nikkel Posted February 23, 2011 Report Posted February 23, 2011 Kronic, There is some good information in this old thread about rigging positions and how they work in reference to how the bars are shaped. http://leatherworker.net/forum/index.php?showtopic=1719 It is hard to tell from pictures because the perspective of the picture distorts things, but if the rigging is placed at all forward of the "roundest part of the front bar pad" (hard to explain what I mean quickly but it is in post #14 in the referenced thread) it will rock the tree forward. There is an idea that is, unfortunately, getting to be more common and we are seeing more trees incorporating it, saying that you need to "flare" the front of the bars out more so they don't interfere with the shoulder blades. So the area of contact with the bar pad ends much further back, leaving a lot of that front bar pad not touching the horse. This sounds like a great idea - until you do up the cinch, which pulls that front end down on the horse and rocks the back up unless it is rigged really far back so that the pull is behind where the contact leaves off. I'm not sure from the pictures. So you think this tree may have been built with that concept in mind? Quote "Every tree maker does things differently." www.rodnikkel.com
Members Round Brim Hat Posted February 23, 2011 Author Members Report Posted February 23, 2011 I'm not to sure if its something they were trying to do with the tree, its a Texas Saddle Co brand that is sold by Frontier Western shop. I talked to the guys down there and they have never had anyone complain about the saddle not fitting the horse (or no one cared enough to worry about it). I also have a friend that bought one of these saddles and had to do very little to it to get it to fit better. Carl down near Rocky Mountain House looked at it as well and did a little work on it for him. Kronic Quote
Members Round Brim Hat Posted April 25, 2011 Author Members Report Posted April 25, 2011 So i finally got enough winter coat off one of the horses to fit the tree without anything underneath it. First try was with the stirrup leathers in, usual happened back end came way up. Took them off and it made a big difference, still not totally great but way better. Quote
