I purchased a used Adler 205 Stitching machine, but it is so fast, I asked what to do from the seller, he said I just need to get used to the pedal, but it is either stopped or in high speed. Is there a way to slow it down?
hello yes there is does your 205 have a speed reducer on it that is a bracket mounted under the machine where the belt on the motor run to a bigger pulley and the belt on the head of machine hooks on a smaller pulley . you can also use a 1 3/4 pulley on your machine motor also i just purchased a new motor from weaver that has a dial on it to run as slow or as fast as you want it is great!!!! i also have a 205-64 alder. they also sell the speed reducers hope this helps john
when it comes to helping others always remember someone helped you once[feel free to visit my galleryEmail me
also i forgot to tell you that the new motor cost 99.50 which is the best price around most people get 145.00 to 150.00 john
Hello there...
You can do several things...get used to the pedal....work the clutch.....that takes some training, but after a while u get the hang of it and get slower....Or you can get a speed reducer, a bracket with different size pulleys to reduce motor speed, as last post mentioned.....then there is a much smaller pulley on the clutch motor itself....that helps some....just reduce the pulley to the smallest possible.
The cream of the cream is a DC servo motor......that baby slows it down BIG time....mounts easy just as your old motor.....there are differnt ones out there....watch the available watts and see if you want build in set of gears to really reduce speed and gain stitching power....that's what I have, a DC servo motor on my Adler 105-64...works like a dream!!!!
I can start a stitch cycle....go and make me a sandwitch and be back before the cycle is finished :thumbsup:
You can go from extreme slow to race the beast.....especially as a beginner which meself it still is, haha....
Call different people and also call Bob Kovar from Toledo sewing machines in OH....that's where I got mine from, you love that one!!!
Need pics and info from that motor,,,,give me a shout..
Greetings
James
http://www.elfwood.com/~alien883
First it is just leather....then it is what-ever I can dream off...
I second what JimBob told you about the SewPro motor. I bought mine from Toledo Industrial Sewing Machines and it is a God send. I used to hand wheel around belt and strap tips, with my well adjusted clutch motor. Now, I use the servo motor to sew at 1 stitch every other second, guiding the work with two hands.
BTW: The SewPro 500GR from Bob Kovar has a 2 inch pulley. This really slows down the maximum speed, while multiplying the torque. My hot-rodded walking foot machine is now capable of sewing 1/2 inch of leather, at slow controllable speeds, without slippage, thanks to that little servo motor.
Posted IMHO, by Wiz
I apologize for not knowing much about the different motors, the servo motor, is this a motor that completly replaces the current motor, or is it an extension added to the current motor?quote name='Wizcrafts' timestamp='1301978332' post='194153']
It replaces the existing motor and switch box, with its wiring.
Posted IMHO, by Wiz
Thanks much! You have been very helpful.
Hi again, Will a sew pro 500 GR be compatible for my machine? The numbers are 205-374. I would like to purchase one if it will work, also how do I measure for the right belt?
Yes, it will work on that machine just fine. The 500GR has built-in 3:1 gear reduction. This makes it more powerful than it looks. It also limits the top speed of the motor to 1500 RPM.
The SewPro 500GR mounts a little closer to the table than a clutch motor. You will lose one inch of belt length, if the motor feeds the machine directly, without a speed reducer. If there is a reducer in the system the belt change may be negligible and easily compensated for via the motor adjuster bolt. If it is feeding all the way up to the flywheel on the machine, buy a 1" shorter belt. If the pulley on the original motor is larger than 2 inches, subtract another inch for each inch that the SewPro is smaller.
In my case, I replaced a clutch motor that had a 2.5" pulley with the SewPro motor and a 2" shorter belt. This positioned the motor a a favorable angle for the pedal rods to pull smoothly.
Doh! I almost forgot the last question you asked!
The existing belt will have a number after a letter. The letter probably is M. The number indicates the length of the belt, at the inside of the tapered belt's circumference. For instance, if the original says it is an M44, and the original motor has a 2" pulley, you would then order an M43 belt with the motor. If the original pulley is 2.5 or 3 inches, you would order an M42 belt (assuming a 44" to start with). The threaded adjuster allows for about 1.5 inches adjustment, up or down from the center point. But, the good operating angle occupies a range of about one inch, from the center down. Each pedal setup may differ from others and your floor pedal may allow a full range of adjustment, up or down, without binding. Mine didn't.
Edited by Wizcrafts
Posted IMHO, by Wiz
