Members r lenna Posted April 6, 2011 Members Report Posted April 6, 2011 anybody know where to find the parts to make the handle and the two ends. I'm not looking for the leather washers,I'm looking for the other parts. I'm looking to fix one for myself. I would like to know the right way to do it. I put one togeather so I would have something to use. Its not pretty but it works. I'd like to hear what anyone else is doing. Thank You Quote
Members rawhide1 Posted April 8, 2011 Members Report Posted April 8, 2011 r lenna I think most folks turn the handle themselves and go to the local hardware store to get the long carriage bolt , washers, and nuts. Mike Quote
Members r lenna Posted April 8, 2011 Author Members Report Posted April 8, 2011 I already did one that way. I thought that there has to be a better way than that. I'll have to keep looking....Hey Thanks a lot. Quote
Members Big G Posted April 9, 2011 Members Report Posted April 9, 2011 what is the plastic part of the maul made from, nylon delrin? Quote If a job is worth doing at all, it is worth doing right
Members BIGGUNDOCTOR Posted April 9, 2011 Members Report Posted April 9, 2011 Being a machinist myself I would suggest getting a hold of someone with a metal lathe. They can make the ends any way that you want them. Quote You laugh at me because I am different. I laugh at you because you are all the same.
Members r lenna Posted April 9, 2011 Author Members Report Posted April 9, 2011 To tell the truth I'm not sure what it is. I got it from work when it was in the trash. I used it for a lot of things. I have some I use for cutting boards, and hammer and tooling stamps. I have some stamps I've made that are 5/16 around and I can pound on them all day long and nothing hurts it. When I use it as a cutting board it's so hard that some times I could swear it dulls my knife. I used my maul to pound and Osbourn 1/8 thonging chisel thru three layers of what had been 13 oz veg tanned leather that I skived down to 8 to 6 oz and it didn't even skuff it. Quote
Members BIGGUNDOCTOR Posted April 13, 2011 Members Report Posted April 13, 2011 If it is something like Delrin, it may eventually fracture. I have machined Delrin, and it cuts really nice, like soft metal. Nylon will be softer, and more flexible, withstanding repeated blows better. Picture, or what color is the plastic? Quote You laugh at me because I am different. I laugh at you because you are all the same.
Members r lenna Posted April 16, 2011 Author Members Report Posted April 16, 2011 Its white. my wife seems to have disappeared with it again. I'll try to get a photo on when I find it Quote
Members BIGGUNDOCTOR Posted April 16, 2011 Members Report Posted April 16, 2011 The Delrin that I have used has been either bright white, or black. Delrin is very hard, you cannot press a fingernail into it. It is also fairly brittle, and will not flex much before cracking. I used it for bushings on some machines I was working on. When you cut Delrin the chips come off clean. Nylon comes in a wide variety of colors, and durometers (hardness). Most of the nylons that I have worked with were soft enough that you could dent them with your fingernail, but they can be hard also (stocks for the Remington Nylon 66's for example). The nylons that I have used usually left flags along the edges that needed to be trimmed off after cutting. Whatever you have, you want to make sure that it is not so brittle to chip, or shatter on the face, and possibly causing eye damage. Quote You laugh at me because I am different. I laugh at you because you are all the same.
Members r lenna Posted April 18, 2011 Author Members Report Posted April 18, 2011 Heres a pic of it Quote
