Members BBAYS Posted May 6, 2011 Members Report Posted May 6, 2011 A question for those of you that airbrush your finish. How or what do you finish the inside of the holster with? I personally dip mine but really like the looks of the airbrushed finish. Wondering how you treat the interior? Thanks Quote
Members Leatherimages Posted May 6, 2011 Members Report Posted May 6, 2011 I just slick mine with a handful of gum trag. Quote
Members particle Posted May 6, 2011 Members Report Posted May 6, 2011 Burnish the interior with Gum Trag, then airbrush the finish inside the holster, wait a moment for the finish to soak in, stick my fingers inside the holster to hold it, then continue with spraying the exterior. Let it dry in front of a fan, then repeat once it's dry. I usually spray a little heavier coat on the interior with the first application. Quote
Members Shooter McGavin Posted May 6, 2011 Members Report Posted May 6, 2011 Isnt the gum trag actually a barrier of sorts though? I usually dye first, then trag, then seal. Quote
Members BBAYS Posted May 6, 2011 Author Members Report Posted May 6, 2011 Particle, do you mind if I ask what kind of finish you use? Really like your work. Quote
Members particle Posted May 7, 2011 Members Report Posted May 7, 2011 Isnt the gum trag actually a barrier of sorts though? I usually dye first, then trag, then seal. Yes, but I dye very early in the process - way before gumming anything. My previous comment wasn't about dying - it was just about sealing with the finish coat. Particle, do you mind if I ask what kind of finish you use? Really like your work. Thanks! I started using two brushed on coats of Satin Sheen. I would brush it on very heavy, then while it was still wet, I'd take a folded paper towel and (using the same spot on the paper towel) wipe away the excess. I did two coats this way. Then, I started airbrushing on a final coat (over the Satin Sheen) of Resolene. Then......, I switched to Angelus 600 and airbrushed it on. I wasn't really happy with how tacky it felt.... Lately, I've been watering the Angelus 600 down 50/50 with water and brushing it on. The tacky feeling seems to have gone away. I apply two coats this way. If there happens to be streaks, I will airbrush a light final coat. Hope this helps! Quote
