Members Rayban Posted July 13, 2011 Members Report Posted July 13, 2011 It helps me. I've got a couple guys who want thinner belts than 10 oz and yet stiff like a 10. Cannot find a material that I like and have tried all the above suggestions. I want things in life I can't get too. So I am not going to try this anymore for now. Thanks guys, Kevin Kevin, try hard rolled horsehide, 8oz of that should do em. Quote Raybanwww.rgleather.net
Members The Latchkey Cowboy Posted August 14, 2011 Members Report Posted August 14, 2011 Has anyone tried the bag stiffener sold by tandy? Quote
Members busted Posted August 15, 2011 Members Report Posted August 15, 2011 HELLO AMERICA! What are good stiffeners for belts, a secret held by those who know!?? Some say zink..stainless steel, plastic, spring steel, Galvanized metal, copper,Egyption secret metal, even unknown elements from other planets! Well.. share the secret to the best stiffeners, please. My wife and children are being held hostage until the best material is divulged! ..After one week I know not what will happen?.. . Your serious, right? I have been making belts and tack for 8 or 9 years never heard of a stiffener for belts. Maybe you should ask the Chinese. Quote
KAYAK45 Posted August 15, 2011 Author Report Posted August 15, 2011 Good Morning Busted: Many people (read customers) want a thinner, smaller belt for OWB carry that will fit INSIDE their belt loops. They simply cannot use a 10 or 12 OZ 1 1/2 belt. One answer MIGHT BE to use a stiffener material between thinner, say 3 OZ leather. Many gun belt makers are currently using a stiffener layer of different sorts. The answers to my question point out others here are using them. Kevin Quote Once believed in GOD and the DOllAR...... Hello God!
Members busted Posted August 16, 2011 Members Report Posted August 16, 2011 Good Morning Busted: Many people (read customers) want a thinner, smaller belt for OWB carry that will fit INSIDE their belt loops. They simply cannot use a 10 or 12 OZ 1 1/2 belt. One answer MIGHT BE to use a stiffener material between thinner, say 3 OZ leather. Many gun belt makers are currently using a stiffener layer of different sorts. The answers to my question point out others here are using them. Kevin I read here some one suggested that you use the horse hide. It is excellent for what you are trying to do. You want an 8 ounce belt that will almost stand by itself in the corner. Right? I have some 4 ounce vegetable tan material that is a very firm hand it should do what you want. You can't bend this stuff to a right angle or it will crack but for a belt liner I think it will work. PM me with your address I will send a sample to you. Quote
Members ramrod Posted August 18, 2011 Members Report Posted August 18, 2011 Has anyone tried the bag stiffener sold by tandy? i bought something from joann fabrics that is very similar to the tandy bag stiffener. i use it merely as a filler to fill out the belt to give it a bit more "body" if you will. i'm not sure it will act as a true stiffener for a belt, though. Quote
Members markush Posted August 18, 2011 Members Report Posted August 18, 2011 (edited) I haven't seen it mentioned here but Looper and Aker belts (been wearing an Aker for 2 years now) advertise using "Kydex" in their reinforced belts. I know next to nothing about Kydex and what I do know of it is that it's a thicker material that is used for holsters etc. and in that case it seems to be thick and stiff enough that it will crack or break. If it's thin enough does it flex instead of crack? If it is Kydex in my Aker belt it is definitely flexible enough for a belt and hasn't seemed to crack or break up at all. Edited August 19, 2011 by markush Quote
hidepounder Posted August 19, 2011 Report Posted August 19, 2011 (edited) I dont think this sub-forum gets as much traffic as some of the others. My 5.11 belt has a thin layer of white plastic of unknown material. More than likely HDPE. If it's white it's probably High Impact Styrene which comes in many thicknesses. It's what I use use when I insert stiffeners. I guess you could use the acquired 'stiffener' in the areas where it will make contact with the holsters to prevent them from wearing out. I do have to say many, many years ago before I became involved in leather, I had my duty belts and holster made by an old guy. My belts were made with two strap pieces glued together equaling 8-10 oz and stitched, no liner. They have held up for over 20 years and still kicking. I use the same concept now when I make my belts. I hope this helps. Isn't the inside layer a liner??? I have built belts on and off for 40 years and I install stiffeners fairly regularly. A lot of times customers are concerned about the tails breaking down and flopping and when that is an issue, I will install a High Impact Styrene stiffener between the belt and the liner. If I'm doing a filigree belt, sometimes a stiffener helps the leather from breaking down at stress points. However if your customer insists on wearing their pants three sizes too small then you will definitely have a challenge on your hands to prevent the center belt loop from folding the belt down and creating a "V". I'm sorry but that's just reality. I suppose a thin metal plate will do the trick and help to prevent or at least delay the deforming of the back of the belt, and there is nothing wrong with doing that....the tough part is deciding whether or not you will explain the problem and fix to the customer or just doing it to avoid insulting them! Edited August 19, 2011 by hidepounder Quote
Members Ken Nelson Posted August 19, 2011 Members Report Posted August 19, 2011 If it's white it's probably High Impact Styrene which comes in many thicknesses. It's what I use use when I insert stiffeners. Isn't the inside layer a liner??? I have built belts on and off for 40 years and I install stiffeners fairly regularly. A lot of times customers are concerned about the tails breaking down and flopping and when that is an issue, I will install a High Impact Styrene stiffener between the belt and the liner. If I'm doing a filigree belt, sometimes a stiffener helps the leather from breaking down at stress points. However if your customer insists on wearing their pants three sizes too small then you will definitely have a challenge on your hands to prevent the center belt loop from folding the belt down and creating a "V". I'm sorry but that's just reality. I suppose a thin metal plate will do the trick and help to prevent or at least delay the deforming of the back of the belt, and there is nothing wrong with doing that....the tough part is deciding whether or not you will explain the problem and fix to the customer or just doing it to avoid insulting them! Wher4e is the best place to get the High Impact Styrene? Thank you. Ken Quote
hidepounder Posted August 19, 2011 Report Posted August 19, 2011 Wher4e is the best place to get the High Impact Styrene? Thank you. Ken Ken I get it from a plastics supplier. They are a wholesale outfit and they sell the High Impact Styrene in 4'x8' sheets. Quote
