Members Glendon Posted June 25, 2011 Members Report Posted June 25, 2011 Hi everyone. I am getting started in sewing leather, and sewing in general. I have a basic question that I just can't seem to find an answer to. Simply put, with a given length that needs to be sewn, how much thread do I need. There has to be a simple rule that you can use to put in the length to be sewn, stitches per inch, and maybe a rough thread size and get a good estimate of thread needed. But no one seems to have this information online. How do you figure this out please? Quote
Contributing Member TwinOaks Posted June 25, 2011 Contributing Member Report Posted June 25, 2011 A minimum of 2.5 times the linear length to be sewn, maybe more. Thread is cheap, use some extra and cut it off. If you DO run short, leave yourself at least 6 inches of thread for back stitching, and start with another piece. If you're going to be sewing a LONG way, like a belt, it's probably better to use pieces of thread no longer than 3 feet. This is because the needle ends of the thread end up going through every hole on the way to the end, and that many passages through the stitch holes will leave the thread looking ratty. It's really simple to tie in more thread and keep it fresh looking....a whole lot simpler than pulling the stitches back out because they're ugly...then adding fresh thread. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
MADMAX22 Posted June 26, 2011 Report Posted June 26, 2011 I have scene mentioned on here and use it as a rule of thumb for my hand sewing is to use a length from your outstretched hands across your chest. No longer. As twinoaks mentioned about the wearing out, also it makes it a ton easier to handle at this length or shorter. For shorter runs or smaller projects you kind of learn how to getstimate the right length that will be atleast long enough with a little extra. Sorry I dont know the proper equation for figuring out the length. Never really needed to do it. Quote
Members Wishful Posted June 26, 2011 Members Report Posted June 26, 2011 Hi everyone. I am getting started in sewing leather, and sewing in general. I have a basic question that I just can't seem to find an answer to. Simply put, with a given length that needs to be sewn, how much thread do I need. There has to be a simple rule that you can use to put in the length to be sewn, stitches per inch, and maybe a rough thread size and get a good estimate of thread needed. But no one seems to have this information online. How do you figure this out please? It really depends on what lace or stitch style you are doing. For instance, I think it is the double loop stitch that uses 8 or 8-1/2 times the length of the area to be laced but the saddle stitch may only need 1.5 times. Tandy has this book for about $3 right now, and others that indicate how much lace and thread to use. Lacing & Stitching For Leathercraft Book Item #61906-00 Quote
Members evandailey Posted June 26, 2011 Members Report Posted June 26, 2011 At 6 stitches per inch through two layers of 8oz, I have found 4x the length to be sewn to be about right to still leave me a decent length to work with towards the end. any less and the last several stitches start to get short on the thread. Bear in mind I only do holsters so I have never done anything needing a length of thread longer than my outstretched arms. Quote
Members Glendon Posted June 26, 2011 Author Members Report Posted June 26, 2011 Thanks so much everyone. Not as clear cut as I was hoping for, but still very helpful. This should get me on the right track until I can get a feel for my own stitching. Quote
Members TexasJack Posted June 26, 2011 Members Report Posted June 26, 2011 Get a copy of Stohlmans, "The Art of Hand Sewing Leather". It has all kinds of great info. Once you've been through it you'll realize that it's not a problem to add more thread as you need to. Use the length of thread that is comfortable to sew. You can always add more or re-use thread that is left over. The book recommends about 8 feet, but that is a bit long for me and I tend to get it tangled. Quote
Members Steven Kelley Posted June 29, 2011 Members Report Posted June 29, 2011 When I was hand sewing, I would outline the stitch line with my thread, then add about 3 inches. Then double it, twice. So I would end up with 4x the length of the stitch line, plus 12 inches. This worked fine for saddle stitching holsters. I never had a piece longer than my arms spread side to side, and always had about a foot of thread left when finished stitching. This method is very easy to do without a measuring tape or anything that fancy. Just pull it off the spool and trace the stitch line with the thread, add 3 inches, bend the thread over and pull off more until it is double, then do it again. Quote
Members Big O Posted July 3, 2011 Members Report Posted July 3, 2011 I "measure" the stitch length with the thread. What I do after that depends on the thickness of the leather I'm working with. Double thickness of 8/9 oz - 4X Double thickness of 6/7 oz - 3.5X 4/5 oz + 2/3 oz - 3X I generally end up with a little extra, but I prefer that to coming up short. Quote https://www.facebook.com/BigOGunleather
Members ramrod Posted July 4, 2011 Members Report Posted July 4, 2011 excellent thread. i've found that i'm averaging about 4x the length of the project as stated a couple of times here. if you use too long of a thread at once, it gets a bit too hard to handle - along with it getting ratty looking. Quote
