Members Anne Bonnys Locker Posted June 28, 2011 Members Report Posted June 28, 2011 Okay folks, edumacate me. It appears that around the world one of the favourite threads for machine sewing leather is bonded nylon but why? Yes, it has the advantage of being enormously strong but it does have a bunch of negatives: - Has all the tactile pleasure of wire rope. - So strong that it will rip through leather rather than break. - If pulled will cut into the surface of the leather. - Not great UV resistance. - Looks like synthetic. What is the opinion on something like core-spun poly cotton or high tenacity polyester? Quote
Members awharness Posted June 28, 2011 Members Report Posted June 28, 2011 I use Polyester and I really like it... -Andrew Okay folks, edumacate me. It appears that around the world one of the favourite threads for machine sewing leather is bonded nylon but why? Yes, it has the advantage of being enormously strong but it does have a bunch of negatives: - Has all the tactile pleasure of wire rope. - So strong that it will rip through leather rather than break. - If pulled will cut into the surface of the leather. - Not great UV resistance. - Looks like synthetic. What is the opinion on something like core-spun poly cotton or high tenacity polyester? Quote
Moderator Art Posted June 28, 2011 Moderator Report Posted June 28, 2011 Hi Darren, For a long time I used Rice Nylon. It had very good hand and ran through the machines smoothly. In fact, a lot of leatherworkers used it. I also used Coats DaBond poly and found it a good thread and I started leaning on it after Rice went under. Then the guy who always sold me Rice started pushing Linhanyl which was also very good. I also use Eddington poly as it has a different look for period Western gear. Basically, you use what works best for you, and you can source reliably. I use linen in the needle and awl machine, and occasionally Eddington poly as it is a little hard to get anything but a shade of white in linen. For insoles in shoes I use 130 lb. Dacron woven fishing line. I guess you are always looking for that "magic" thread, but when you need to sew, it's what is in the machine that counts. Art Okay folks, edumacate me. It appears that around the world one of the favourite threads for machine sewing leather is bonded nylon but why? Yes, it has the advantage of being enormously strong but it does have a bunch of negatives: - Has all the tactile pleasure of wire rope. - So strong that it will rip through leather rather than break. - If pulled will cut into the surface of the leather. - Not great UV resistance. - Looks like synthetic. What is the opinion on something like core-spun poly cotton or high tenacity polyester? Quote
Members Anne Bonnys Locker Posted June 29, 2011 Author Members Report Posted June 29, 2011 We ran TEX400 bonded through a 132k6 clone yesterday, or tried to, the machine hated it. Admittedly we didn't have a lot of time to play with the setup but my partner has 30 years of industrial sewing under her belt and has never seen a machine spit out a thread like that. Same weight of core spun and it ran like a dream. Quote
Members oldtimer Posted June 29, 2011 Members Report Posted June 29, 2011 The core spun poly-cotton ( Barbour) I have used looked great at first, but it wore fast and looked fuzzy and terrible after a while, so I´ve got rid of it and now I use bonded nylon only. I have been told that the core-spun polt/cotton isn´t meant for leather but for fabric and tarp . / Knut Quote
Members Caffy Posted July 22, 2011 Members Report Posted July 22, 2011 Hello all, Can anyone tell me a conversion for size thread to weight? I use mostly 277 size and was trying to get some colors other than the standard, black, white and brown. I called a company that seems to have a lot of colors in the nylon and poly, but they sell and weight only and they have no idea what weight 277 is. I thought a thread company would know, but they don't. Does anyone have a conversion for this. I use 138 also for some light weight things. Thanks in advance. Keep cool, Caffy Quote
Members McJeep Posted July 23, 2011 Members Report Posted July 23, 2011 Will this answer your questions??? Not exactly sure which number you need but hope it helps - found it here a couple weeks ago http://www.amefird.com/wp-content/uploads/2009/10/5-Thread-Size-Comparison-Chart-2-4-10.pdf Quote
Moderator Art Posted July 23, 2011 Moderator Report Posted July 23, 2011 Hi Caffy, A&E is probably the best at publishing their technical information, as such sometimes it is hard to find what you really need. You can find the appropriate chart here. Art Hello all, Can anyone tell me a conversion for size thread to weight? I use mostly 277 size and was trying to get some colors other than the standard, black, white and brown. I called a company that seems to have a lot of colors in the nylon and poly, but they sell and weight only and they have no idea what weight 277 is. I thought a thread company would know, but they don't. Does anyone have a conversion for this. I use 138 also for some light weight things. Thanks in advance. Keep cool, Caffy Quote
Members Caffy Posted July 24, 2011 Members Report Posted July 24, 2011 Thanks so much for your reply! I use 277 mostly. Caffy Hi Caffy, A&E is probably the best at publishing their technical information, as such sometimes it is hard to find what you really need. You can find the appropriate chart here. Art Quote
Members Caffy Posted July 24, 2011 Members Report Posted July 24, 2011 Thank you very much. Great chart. Will this answer your questions??? Not exactly sure which number you need but hope it helps - found it here a couple weeks ago http://www.amefird.c...hart-2-4-10.pdf Quote
