Members gary jackson Posted August 11, 2011 Members Report Posted August 11, 2011 Kia Ora, has any one used or have an opinion on a Seiko STW8B, I am looking to use it on Rodeo Chaps and Handbags, hope you are all well out there and stayin` safe. Quote
Members amuckart Posted August 11, 2011 Members Report Posted August 11, 2011 I've never used one, but it looks to be similar to the STH-8, which I have but is a vertical-axis hook machine that takes a smaller bobbin. I take it you're looking at the one on TradeMe? I got my STH-8BL for NZ$350 in pretty good mechanical nick, but set up for upholstery. I got it to do tent repairs, for leather it'll need a servo motor and a different needle plate. Wiz has a similar machine set up with no feed dog and a slotted needle plate for leather. There's a $1 reserve Pfaff on there at the moment, currently at $30 that'll probably end up going cheap but it needs some work by the looks of things. I plan on getting a set of feet and a roller guide for it and getting a slotted needle plate laser cut. The thing that might get you about the STW-8 is that it's max stitch length is 5.5mm and it takes small bobbins. For leather, I'd hold out for the STH-8 or a Consew 206. There seems to have been a fairly steady flow of this class of machine on TM for the last little while. I see one guy with a couple of new in-the-box STH-8BLD3 machines for NZ$1400. Quote
Members gary jackson Posted August 11, 2011 Author Members Report Posted August 11, 2011 Hi Al, thanks for that probably a bit technical for me, I see the Pfaff you are talking about, it is the same as one I checked out today it is relisted at $420, I tried it on some mockups but it lacked the grunt with 69 thread. Isn`t this sight an amazing access to some very clever and gifted Leather Smiths and information. We have to catch up sometime. Quote
