Does any one now how or now where i may fin info on making my own manual and electric burnishers?
Dremel tool or drill press. We have a couple of members on here that make the burnisher attachments.
Good luck!
thanks for the info king's x. i have the dremmal just need the attatchment or info on making them my self
Hey Donnie,
I made them for the dremel but if you have access to a lathe and simply need info, drop me a line.
my website is also below.
Chris
What tip number do you use for the dremel?
I actually use the 1/4" sanding drums. The sandpaper and rubber bushing are recycled leaving the shaft, washer and screw. The shaft where the burnisher wood bit goes is 1/8" dia. x 1/2" long.
Edited by Spinner
