Members Go2Tex Posted June 9, 2008 Author Members Report Posted June 9, 2008 Thanks Brian. Interesting way of doing it. Might save some time if I just dunk one side at a time the next morning. Like you say, just give it some color. Not so much time wasted waiting for it to dry enough to tool. Ditto on not re-wetting the carving but trying to get a carved seat back into shape to fit the tree can be a challenge. I try to wet it down on the back side but it bleeds through a bit. Any tips on dealing with the inevitable stretch from a large carved part like a seat? The fit is so crucial but once it's carved it's like trying to put toothpaste back in the tube. Quote Brent Tubre email: BCL@ziplinkmail.com
Members steveh Posted June 9, 2008 Members Report Posted June 9, 2008 Thanks. The pattern was cut down from a previous one for a 16 inch seat. This one was 14. I spent tons of time on the original working out the flow and several hours making it work for this seat. Everytime I do one I think it's the best and then the next time I pick it up to use it I end up redoing much of it. I guess that's natural. Once I carve it, I see problems and things that didn't work well. The intertwining vines, or overlaping vines, allows for the flower circles to be placed closer and makes it easier to adapt to an odd shape, like a seat or cantle or whatever. Once you have a the basic pattern of flow for the overlap from one circle to the next, you just keep repeating it from one circle to the next. I use a piece of viewfoil film with my circle pattern on it and a few other cheater features, like the swirls and leaves. Mylar drafting film works the best for making patterns, by the way, but is sure is expensive, now that I'm buying it myself. Very nice work. What is viewfoil film with your circle pattern on it , all about?Please explain. steve Quote
Members Go2Tex Posted June 9, 2008 Author Members Report Posted June 9, 2008 Viewfoil is a medium used in a photocopier to make overhead projector presentations. It is fairly firm, clear plastic on both sides, unlike mylar that has one or both sides with a surface that can take pencil or ink and is erasable. The viewfoil is great for laying over your wet piece of leather and finding your edges, or copying a pattern because it is perfectly clear and is not affected by the moisture, as would be tracing vellum. I use a fine point felt tip marker on the viewfoil. It will rub off, however, so be careful when turning it upside down for the reverse side, especially on wet leather. Use an indelible ink pen. A circle pattern is the basic design element for Sheridan style carving. The vines and pedals swirl around the circle and terminate at the flower. Each circle flows to the next with connector vines, with other features interspersed to break up the monotony or fill in a open space. When laying out a design, a circle pattern can be placed under the design and traced, rather than using a compass. A piece of mylar or viewfoil can be layed over the design to check to see how it looks or if it fits, etc. Filler features, like swirls or leaves can also be put on the viewfoil to aid in laying out your design. Quote Brent Tubre email: BCL@ziplinkmail.com
Members jonwatsabaugh Posted June 9, 2008 Members Report Posted June 9, 2008 Tex, Very, very nice carving and tooling! As far as fitting the seat back in after all tooling is done, here's what works for me. While initially fitting and trimming the seat I make sure it's drawn in very tight. I draw spike the seat in 6 places. The rear concho ears, the srew hole at the base of the fork, and the front concho ear where the skirt meets the fork. I also "iron" the seat leather before the fitting begins to get some additional stretch. I do this by taking a very smooth hard wood slicker and burnishing the leather on the flesh side on my rock pulling from center out all the way around the piece. With these 6 places to re-index the seat it always fits back where I want it after its tooled. Hope this helps. Jon Quote
Members Go2Tex Posted June 10, 2008 Author Members Report Posted June 10, 2008 Thanks for the ideas. I do the same thing except for the tempering on the flesh side. Be interesting to see that done. But, alas, the seat went back in, albeit very snug at the ears and it usually is for some reason. Might have to do some finesse on the ear cut but then, I usually do anyhow. Spent the day tooling one fender. Tried that idea of wetting from the back side and all that did was make it uneven. Had to put both fenders back in the plastic bags to even out. That wasted time. ehem...... But, once I finally got started, about 1:00pm, all went well. and in a short 6.5 hours I had the following results. And now it's Miller time! Actually Shiner time, but ya'll probably don't know what that is..... Quote Brent Tubre email: BCL@ziplinkmail.com
Members kseidel Posted June 20, 2008 Members Report Posted June 20, 2008 Finally had a few minutes to go back and read some old posts and found this one. First, nice carving.... We have seen this saddle finished and it is beautiful. Clear-lay plastic film is a great clear plastic to use for pattern layout. It is available in large sheets from art supply stores. Using a permanant felt tip marker like a "Sharpie" and it will not rub off. You can use denatured alcohol to wipe it clean and re-use film for more patterns. You are a pretty fast tooler to do a seat panel in 4.5 hours and a fender in 6. Nevertheless, it does dry out faster. I don't wet as thoroughly as some. Certainly deep into the fibers, but not completely thru the entire thickness. I only wet one panel at a time. If you don't wet as much you won't get sa much stretch. Here in WY. we have to deal with shrinkage more than stretch.... no humidity. Sometimes a seat will shrink as much as a full inch front to back! Not wetting as deep helps with that as well. Depending on the leather that you use, you may find that you can tool a great deal drier. In most cases each re-wetting will cause the tooling to swell and not stay as deep, so unless it is unavoidable, I keep the panel moist until finished. Re-wet and bag it overnight. The key is not to over-wet the partially tooled leather. I use a presure sprayer to wet leather for tooling, much finer and more consistant spray than a spritzer. I can apply a fine mist to the surface and within moments return to stamping. This more frequent but minute wetting wicks into the deeper fibers making deep re-wetting unnecessary. I get a lot of interuptions, and usually just put the piece in a plastic bag and when I get back to it (sometimes the next day) only a light spray and it is ready to stamp again. Another tip, when drawing your patterns, make some flowers without full circles of vines all around. Let some flowers lay against the borders or the vines around other flowers without having their own full circle. It helps add variety and break up the "grid" look. Keith Quote Keith Seidel Seidel's Saddlery www.seidelsaddlery.com
Members Go2Tex Posted June 20, 2008 Author Members Report Posted June 20, 2008 Finally had a few minutes to go back and read some old posts and found this one. First, nice carving.... We have seen this saddle finished and it is beautiful.Clear-lay plastic film is a great clear plastic to use for pattern layout. It is available in large sheets from art supply stores. Using a permanant felt tip marker like a "Sharpie" and it will not rub off. You can use denatured alcohol to wipe it clean and re-use film for more patterns. You are a pretty fast tooler to do a seat panel in 4.5 hours and a fender in 6. Nevertheless, it does dry out faster. I don't wet as thoroughly as some. Certainly deep into the fibers, but not completely thru the entire thickness. I only wet one panel at a time. If you don't wet as much you won't get sa much stretch. Here in WY. we have to deal with shrinkage more than stretch.... no humidity. Sometimes a seat will shrink as much as a full inch front to back! Not wetting as deep helps with that as well. Depending on the leather that you use, you may find that you can tool a great deal drier. In most cases each re-wetting will cause the tooling to swell and not stay as deep, so unless it is unavoidable, I keep the panel moist until finished. Re-wet and bag it overnight. The key is not to over-wet the partially tooled leather. I use a presure sprayer to wet leather for tooling, much finer and more consistant spray than a spritzer. I can apply a fine mist to the surface and within moments return to stamping. This more frequent but minute wetting wicks into the deeper fibers making deep re-wetting unnecessary. I get a lot of interuptions, and usually just put the piece in a plastic bag and when I get back to it (sometimes the next day) only a light spray and it is ready to stamp again. Another tip, when drawing your patterns, make some flowers without full circles of vines all around. Let some flowers lay against the borders or the vines around other flowers without having their own full circle. It helps add variety and break up the "grid" look. Keith Thanks again for the compliments and tips Keith. I don't have to worry too much about stretch or shrink on my seats down here, although I did get a little bit of stretch on this one. But it has been a real adventure moving from one area of the country where it's cool and wet to an area that is hot as hell and humid one day and dry as west texas the next. It's been weird and hard to get a handle on it but I was very pleased with the outcome on this project. It was slow drying but at least it did finally get there. Last year when we got down here it had been unusually wet and the leather would simply not dry. I have the option of taking the piece outside and letting it take in some hot sun rays to hurry it up a bit. I will definitely follow your advice about not wetting all the way through and just one panel at a time. It will take all the stress out of it, not having to rush one panel before the others get too dry. I also like your advice about the pattern grid look. I'll rework this one with that idea in mind next time. Right now I'm breathing a sigh of relief and enjoying the brief resbit. Got notified today that the saddle cleared customs and was delivered to the customer. WHEW! What a hassle that was. With a huge trade deficit, one would think the government would make international trade easier instead of making it more difficult. It was a nightmare of red tape and bureaucratic BS. But it's history now! Quote Brent Tubre email: BCL@ziplinkmail.com
Members texdeputy Posted July 20, 2013 Members Report Posted July 20, 2013 with that amount of carving it is going to take a long time. Your carvings are as good as any I have seen. don't know how long you have been doing this but I bet you will get faster over time. I like the spray bottle idea and the fact that you cover the area you are not carving with plastic wrap. keep up the great work. and I know what a shiner is. Quote
Members undeberg Posted August 16, 2013 Members Report Posted August 16, 2013 I have found that if you taper off water application for re-wetting purposes you don't have to worry about any water lines either. I bought a pump up sprayer and put it on the fine mist setting and I spray the boundary of where I'm carving with that a couple of times. This does result in a bit of rewetting on carved areas, but it's not a full saturation so it doesn't loose crispness due to swollen fibers. Basically, I'll dunk the area I'm going to work, and just mist the boundary a couple times to transition the leather. Quote
Members thecowboy7 Posted January 2, 2014 Members Report Posted January 2, 2014 Your carvings are fantastic... and now I find myself craving a Shiner. Quote Twin Mountain Saddlery Fredonia, KS ~ Del Norte, CO www.twinmountainsaddlery.com Phil 4:13 - I can do all things through Christ who strengthens me.
