Shooter McGavin
Best Buckle For Really Thick Belts?
So I made a dual layer shark trimmed gunbelt for a buddy of mine. The end with the buckle holes is pretty thick, maybe like 5/16... The roller bar buckles I normally use from Tandy want to sit at about a 45 degree angle which isnt sexy at all. I'm thinking I need a buckle that has an offset or something. Can anyone help me out?
Thanks!
Thanks!
Maybe "ranger type" belt can do the trick?
You know, thome thing like this:
Edited by Tverd
Thanks!
Shooter,
Have you tried an "Oval" hole punch. Maybe the additional width in the hole area would help that lay down? Can you post a picture?
I used a #7 (?) oval punch for the holes. Also, I dampened around the holes on the back of the belt and indented each one with the end of my wood slicker tool. That helped a bit. I've alread shipped it off, and the guy says he loves it and doesnt have any problems with the thickness in the front.
Sometimes I create problems where none exist I suppose.
Heres the belt though.
Edited by Shooter McGavin
