Here's my take on a classic. My customer ordered it in left hand for his new model Ruger vaquaro. The "copy" Colt in the pictures is mine. Anyway, I hope he likes it, I was very pleased with how it turned out, what do you all think?
Thanks,
Josh
post-19070-032798300 1317737473_thumb.jp
post-19070-058740800 1317737485_thumb.jp
Edited by Josh Ashman
Thanks,
Josh
Josh, I like it ..... a nice piece of work. I personally prefer open toe holsters ..... but that's just me. It's mainly from a lot of years of seeing the crud that collects in them over years of use. I can't see how you do your hammer thong. I make mine adjustable, but tight and fairly open .... simple to ease off with the thumb, like this one on a 'Threeperson' style BBQ holster, but firm and thight enough to serve the purpose. Mike
NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!!
At my age I find that I can live without sex..........but not without my glasses.
Being old has an advantage.......nobody expects me to do anything in a hurry.
That is a sweet Rig. Your customer will love it for sure.
I was looking at the John Wayne "Big Jake" Rig in a magazine just last night and your rig is just about as spot on as can be from the looks of it.
I'm playing around with the Cowboy rigs now. Hope to get to this level in time, very nice....
No sir, he fell into that bullet
katsass,
I like an open toe holster as well but as near as I can tell the ones John Wayne had made were closed toe so I went that way. Closed toe are fine too, if the holster flows and fits right it's hard to go wrong.
For my hammer thongs I run a 1/4" lace with beveled edges through the holster body and tie an overhand knot with one side over the other side. Pull the knot up tight to the holster, twist the loop side several turns until the length is about right and put the end over the hammer. It's not fancy or tricky but it works well enough.
Reaper,
Thanks for the compliment, I hope you're right about my customer. Good luck and have fun playing with "cowboy" rigs. I sure think they're fun to make.
Best regards to you both,
Josh
katsass,
Reaper,
Josh
Josh, since my holsters are almost all made from two layers of leather ... bonded to each other on their flesh sides, I run the end of a thong onto a hole on the outer layer, knot it, run it up and form the loop, then down into one more hole in the outer layer, and out a second one. The friction of the two bonded (except on the thong) and stitched layers holds tight .... but the thong is allowed to be adjusted with a bit of effort. Of course a Threeperson's style holster is almost always closed toe, but as you did, I leave a little bit open to allow most of the crud to slip out. Again, very nice work. Mike
Edited by katsass
Mike,
It sounds like your hammer thongs work very well. Nice job on your holster for the S&W, the arrowhead inlay, native symbols and finish all combine very well for a cool look.
Best regards,
Josh
You did a great job on the holster and the belt. There are so many variations of that style out there. This is the one that I did for a customer a while back. I do have several close up photos of a few rigs owned by John Wayne, which help a lot. Most of his were open toe holsters.
Frank
Never argue with a stupid person. They'll just drag you down to their level and beat you with experience!!
Mike,
Best regards,
Josh
Thank you Josh for the kind comments on my holster. It was made for the local chapter of "The Friends of the NRA". The symbols you mention are replicas of western cattle brands, burned into the leather, and this holster was named 'A Tribute to the American West' . Mike
Frank,
That's a heck of a rig yourself, "great job" back at ya. I'll bet the close up's helped a lot, I knew I had the top cut too high but I hadn't realized they were mostly open toe. I guess the stitch line I was seeing was the lining, learn something new everyday.
Best regards,
Josh
Good Job Josh. I am a huge John Wayne fan and I love this rig.
What did you make the belt out of and did you reinforce the single layer behind the bullet loops or did you just leave it as a single layer?
"Courage brother, do not stumble, though thy path be dark as night: There is a star to guide the humble, trust in God, and do the right. Let the road be dark and dreary and its end far out of sight. Face it bravely, strong or weary. Trust God, and do the right." - General Norman Schwarzkopf
