Members knot much Posted November 28, 2011 Members Report Posted November 28, 2011 Thanks for the tips Brad, I'll be giving it a shot in the next day or two. I've started a hackamore and got the core covered in 12 pl. and the two ring knots on for the nose button. It's gonna be a real "raggy" "floppy" one as I didn't realize that just a 4 strand reata like braid would be that limber when covered. I thought about starting a new one but figured I'd go ahead and finish just to get one under my belt. Jamie I know this thread is a bit old, but I thought I'd mention a twisted rawhide core can work quite well. I did one as described in Grant's books. Just make sure the strip has an even thickness, otherwise it will have soft spots that will bend easier and you'll end up with a weird shaped bosal. Quote
Members 8thsinner Posted November 30, 2011 Members Report Posted November 30, 2011 I would tend to avoid glue if I can and use methods that are removable and cause no damage in case there is ever a need to take it apart. I will usually use strips of leather wrapped on, using thin stuff if I can makes it neater. Trim the shape with a very sharp knife, and use a slim bar of steel under it to make sure I don't cut through. Then at the outer edges of it through the braid under, attach either dental floss or artificial sinew, and wrap it (flat) as if I was doing a button, ie 20-30 degrees apart past the last one on each pass. every now and again going through the braid again. The artificial sinew spreads out to about 5mm width so it works far better than dental floss which only spreads about 2mm-3mm I used to use tape to smooth the finished look but don't much find the need any more, if the floss is good and tight and even, it shapes it nicely enough. And helps to provide a better grip for the next knot. If I am out of material, I will make more knots using what ever I am braiding with, usually a Spanish ring, if I need a rein type knot, or if it's for the end of a whip, a Spanish ring followed by a turks head followed by what ever know I am using. Quote Doing the right thing is bleeding for the cause. Website Facebook
Members bucksnort Posted July 18, 2013 Members Report Posted July 18, 2013 I could add a couple of ideas to this. I have used Sealtex track bandage with good results. It is latex rubber that only sticks to itself. Since it is rubber, it won't slip when wrapped tight & can be removed with no marks left. As an added benefit, it is tan in color, so it doesn't show thru if you have any gaps. I cut a strip about 1/4 in wide. I bought from ebay. Don Brown uses blue painters tape with good results. He likes it because it resists moisture & won't run any color. Buck Quote
