waddy Report post Posted June 16, 2008 What is a good braid or weave to use for covering a meta ring? Also, what size lace works best? I'm thinking about the 1 1/2" to 2" size rings used as hobble carriers on saddles. Quote Share this post Link to post Share on other sites
Luke Hatley Report post Posted June 16, 2008 WADDY, I HAVE USED THE 3/32 CALIF LACE AND DID A DOUBLE CORDIVAN STICH......THE NARROW LACE WILL LAY BETTER. Quote Share this post Link to post Share on other sites
waddy Report post Posted June 16, 2008 Many thanks Luke. I realize this is a pretty elementary question for you braiders, it is just something I have not had a call for until now. Quote Share this post Link to post Share on other sites
CWR Report post Posted June 17, 2008 Waddy, If you have Bruce Grants books, he calls it the spanish edge lacing of two loops. Its pretty easy to do. Just keep pushing the lace together to get better coverage. This is what most of the rings are covered with. 3/32 rawhide works really good. Cut your string long you don't want to run out. Good luck, CW Quote Share this post Link to post Share on other sites
greg gomersall Report post Posted June 17, 2008 Waddy make sure you use a stainless or brass ring as the chromed steel rings will rust when exposed to the weather and it looks like crap from the inside out at that point. Greg Quote Share this post Link to post Share on other sites
waddy Report post Posted June 17, 2008 Thanks CW and Greg. It always seems to be the little things that end up making the difference. I do have the Grant books and had looked at that. Thanks for reinforcing that it is a good way to do it. I will not buy chrome plated hardware if I can help it, I spent too many years using stuff with the plating peeling off and leaving sharp edges and rust. Thanks again. Quote Share this post Link to post Share on other sites
TomSwede Report post Posted June 17, 2008 Hi Waddy! If you decide to go ahead with Grants Spanish double or triple loop I would love to see the result. Gonna try one of them but can't decide wich since the finished buckle looks the same in his drawings. I don't need to do it right away but just thought it looked like fun to try so don't rush anything on my behalf. Tom Quote Share this post Link to post Share on other sites
