sinpac
Let Play Name That Tool!
I was wondering if you guys knew what these tools might be I found them in my Singer 29-4 wooden box.
The first one looks like a cutter of some sort, and the second looks like a miniature nail puller-maybe for staples?
Cobbler's nail puller for #2?
The second one is used in making shoes and boots. If remember right it's used in pulling the vamp or counter over the last. The bottom piece stays on the shoe or boot and acts as a lever i guess you say plus it holds what ever your pulling tight, leaving one hand to put you nail where you want and then drive it with your hammer. Maybe one of the boot makers will pop in tell what it's called.
No, it is a nail or staple puller. Sometimes perspective can cause misidentification. I have several of #2 and a couple of the tool you mention which is a shank lasting pincer or "bulldog" in the trade. The tack puller in #2 is a lot smaller than a bulldog pincer. The shank laster has solid jaws to grip the leather, either with toothed jaws or an overlip.
Art
#2 Art is right!
This is a useable antique upholstery tack puller. It has a unique design with a steel pivoting lever and one moving, and one stationary jaw to grasp the medium large head upholstery type tacks. The pivot lever allows additional leverage and firmer grasp of the same type tack. It is possible to use it on other than upholstery tacks but seems to work best on tacks with the larger heads.
Thanks Art
The first one looks like a pattern knotcher. This makes tiny nibbles from the pattern material (or leather) so you know which pieces meet up.
The second one is a Kajiggling Pin remover. For those painful times when your kajiggling pin gets out of joint. :D
