I've been asked to make a gunbelt for a customer that is 72 inches to the middle hole. I measured it myself, so I know it is the right size. I've only made a few gun belts, and this will be my second one with the machine. I ordered some 84 inch blanks from Springfield Leather. They should be here next week.
Now for my question. Are there any surprises when making one this size? I can't think, of any, but there could be something I'm not anticipating. I hope the bobbin will hold enough thread to go all the way around.
72 inches to the center hole. +3.5 inches for the fold at the buckle + 2 inches to add 2 more holes after the center hole and 3 inches to the end of the billet.
Thats 82.5 inches in my way of doing a belt. Id make sure Springfield knows you have no room for error in measuring the blank.
Which machine are you using to sew this bad boy? I have no idea if the bobbin will hold enough but I would think that you could sew one side swap to a new bobbin and continue from that point and sew to the back end.
I just finished one that was 56" in length and the biggest problem I had was some place to lay it down while I was dyeing it and putting the finish on it. Other than the size Id recommend a good strong buckle and don't skive the area for the slot too much.
What thickness did you order your blank in?
Michael
Thanks, Michael
I ordered 7/8 oz leather blanks. I will have the same problem. My dyeing area is only 60 inches, so I will have to extend it somehow. I have a Cobra 4. It has a large bobbin, but I haven't had it long enough to know how much a full bobbin covers.
Springfield advertises that their blanks are 84 inches, so I will believe them.
Edited by steelhawk
With a full bobbin you should have plenty of thread to make it around your belt.
Edited by dirtclod
Thanks, Michael
Springfield is very good. If they say 84 then they are 84. Thats great. Have fun with this one and post a picture when its done.
  • 1 month later...
How did this turn out? Any good lessons learned?
tk
It turned out well. I certainly learned more about my machine and belts in general while doing this. I didn't charge enough money for it, though. It is harder to work on one that long, since all my work spaces are shorter. I ended up getting a 6" wide piece of lumber 8 feet long to clamp to my work areas. This made work easier.
  • 2 weeks later...
We've got a couple of orders, in the shop, for 74" belts. That means we have to cut them about 84". It's hard to find a double shoulder that big. But we're looking.
I ordered 84" belt strips from Springfield Leather. During checkout I told them in the comments section that I wanted 7 to 8 oz thickness on the strips.
  • 2 weeks later...
Here's a pic of the finished thing. I has posted it earlier in the holster forum.
Now that's a belt. You would almost have to put a stiffener in it to get the job done.
Nice work, by the way.
Thanks. That means a lot, coming from a great belt maker as yourself.
