Members Treed Posted December 21, 2011 Members Report Posted December 21, 2011 (edited) I'm having problems finishing off the backs of my belts. ( as I'm only just starting out, I'm using Tandy's belt blanks ) I can't seem to get my belt backs nice and smooth like on some pictures on here. Every time I try, it either ends up blotchy, rough or just generally not as I'd like them to be. So, are there any tips and tricks for nicely finishing belt backs off so they come out nice and smooth? Regards Jake I agree with better leather, but that doesn't fix the problem with what you have now. The best fix is get a bottle of Gum Tragacanth from Tandy or other leather provider. Apply a liberal amount to the back of the belt and rub it in, I usually used my fingers. After rubbing it in so that it penetrates good I use a wooden slicker or glass slicker and rub it over the back smoothing out the leather and removing the excess Gum Tragacanth. I then lightly wipe down the back with a paper towel or rag and let it dry. I forgot to mention that if you are dying the belt that this is done before applying the Gum Tragacanth. Gum Tragacanth is a natural glue and I use it on most all of the unlined holsters I do on all the leather, leaves a very smooth and finished product. What ever you use to finish the front also apply to the back of the belt. Bobby R Edited December 21, 2011 by Treed Quote Bobby Rose Rock'n R custom holsters
Members snowgoose Posted December 21, 2011 Author Members Report Posted December 21, 2011 Thanks for all the replies, I will try some Gum stuff and see what happens :D Regards Jake Quote
Members Chavez Posted December 21, 2011 Members Report Posted December 21, 2011 Hi Snowgoose! I'm a newbie here and I haven't made any belts yet, but I'll be making them from 2 pieces stitched flesh-to-sflesh when I do. This does not only let you forget about the flesh side, but it also makes your belt more waterproof, especially if you resolene the back. When you're buying gum trag, make sure you get the liquid "leather" version. I was stupid enough to buy it in powder and its a pain to dilute. It does slick the flesh side but I seem to get a much better result if i slick the back with a cloth empregnated with beeswax after the gum trag dries up. Gum trag might help you slick the flesh side, but it will turn into complete mess the next time you are caught in heavy rain and the belt gets wet. I'll also suggest Leprevo leathers for all your future supplies. The guys are very helpful and charge a bit less than tandy. Quote
Members DoubleC Posted December 26, 2011 Members Report Posted December 26, 2011 best tip is to get better quality leather and leave the tandy leather for others to use. on belts i usually spray on the dye or dip dye them. this helps me get a even coat of dye. i have just started using herman oak tanned leather and realized that this leather is way better than tandys leather. the herman oak is tanned in the united states(which is great for me). the flesh side is way smoother than tandys and takes dye better than tandys leather. after finding out that herman oak is way better to work with than tandys leather i will nolonger buy tandys leather. I mentioned somewhere else I wanted to start making my tack myself (when I say tack, I'm talking headstall, breast collar and reins, not saddles) and being on disability I'm not ashamed to admit that I have to look for the best bang for the buck, and that WAS going to be Tandy. (the herman oak is tanned in the united states). So does Tandy's leather come from China like everything else they sell? My whole business is based around handmade in AMERICA. Cheryl Quote http://www.etsy.com/shop/DoubleCCowgirl
electrathon Posted December 26, 2011 Report Posted December 26, 2011 Most of Tandy leather comes from Mexico, none is USA made. Herman Oak leather is a good choice, Tandy does not sell it, they have live oak, I guess trying to emulate the quality name to trick newcomers. Springfield leather is a good choice. Aaron Quote
Moderator Art Posted December 26, 2011 Moderator Report Posted December 26, 2011 I am going to +1 to Aaron's choice. If you are just starting out, Kevin at Springfield can sell to you in less than full sides which can be easy on the pocket. He has a leather shop on premises, so he can cut you belt blanks if that is what you need. Kevin and clan are always there for any questions if you need that, although don't talk to the dog unless you just need to vent, he isn't that good a leatherworker. Until you get to buying sides of leather, SLC is a good choice, and even after that, if you like Hermann Oak, SLC is still good as HO requires a 10 side minimum. Art Most of Tandy leather comes from Mexico, none is USA made. Herman Oak leather is a good choice, Tandy does not sell it, they have live oak, I guess trying to emulate the quality name to trick newcomers. Springfield leather is a good choice. Aaron Quote For heaven's sakes pilgrim, make yourself a strop!
