I have a Tandy swivel knife and the small brass screw that holds the blade needs replacing. Does anyone know where I can get one? I live in the middle of nowhere and the hardware store has wood screws and bolts.
Thanks
Thanks
Might want to try this place...
http://www.mcmaster.com/#screws/=fgqnrw
You will need to know the dimensions though
Ask your hardware guy for a #8 32tpi set screw, 1/8" long.
If he doesn't have that you can get a 8-32 bolt and cut it to length, but you will want to buy a nut for it so you can remove it from the bolt after you cut it, this will help clean the threads so you don't bugger up the knife.
http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=431-0058&PMPXNO=2622085
Edited by Tree Reaper
Hobby store. Model airplane section. You want a set screw, a regular screw is way to soft to last.
Aaron
A regular bolt will get you by until you can get a set screw.
The regular bolt won't be any softer than the brass screw he had but it will have a head on it which can interfere.
I have to totally agree. If the correct screw was used in the first place, it would likely not need replacing today. Amazing the crap a company will do to save 1/5 of a cent.
Most hardware stores have those boxes with the lift lids that have a pretty large selection of set screws and the clerks sometimes forget about them.
Chances are they have them.
excellent. thanks for the info. Armed with that maybe I can track it down, No hobby stores around here so that is out but with size and pitch maybe it'll turn up
Another possibility is to locate a local gunsmith. He should have a quality setscrew that will do.
(John 8:32) And ye shall know the truth, and the truth shall make you free. (KJV)
And the truth is that religion is nothing more than the lame attempt by largely ignorant people to
bring sense and order to a world that was beyond their comprehension. Once you see religion for the
delusional and superstitious artifact it is............... you will be free !
screws that lock down tandies belt tips in the buckle sets work great.
Lloyd Allan custom Leather (Al)
Find us at facebook.com/LloydAllanCustomLeather
Everyone welcome
