Members Chavez Posted December 24, 2011 Members Report Posted December 24, 2011 Hi! Got myself some nice linen thread which needs to be waxed. The thread was usung before was already waxed when I got it, so here's my question: Do you wax your thread right before sewing, or do you just wax a spool or two in advance on a dark&cold winter evening and then use it when you need it? Is there any difference if the thread has been waxed recently or a few months ago? Thanks! Quote
Members ramrod Posted December 24, 2011 Members Report Posted December 24, 2011 not having used linen yet, i'd say to wax only what you'll be using at that time. seems to make sense only because you wouldn't have to respool a large amount after having waxed a couple hundred feet. Quote
Members Sylvia Posted December 24, 2011 Members Report Posted December 24, 2011 Very good question! I would like to know how the pros here do this too. Here is a tutorial for waxing thread from a quilter. http://www.ehow.com/how_2274907_wax-sewing-thread-quilting-projects.html It involves unwinding the thread around a prepared piece of cardboard, rubbing it with paraffin, then covering the thread with waxed paper and ironing with a warm iron. Since some spools of thread are huge, I would wax several yards at a time, then wind it on a dowel or old wooden spool, for use. Hi! Got myself some nice linen thread which needs to be waxed. The thread was usung before was already waxed when I got it, so here's my question: Do you wax your thread right before sewing, or do you just wax a spool or two in advance on a dark&cold winter evening and then use it when you need it? Is there any difference if the thread has been waxed recently or a few months ago? Thanks! Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members Chavez Posted December 24, 2011 Author Members Report Posted December 24, 2011 Thanks for the link sylvia. How does this iron method compare to the Al Stohlman's way described in "Hand stitching" book? (i.e. just feed the thread through a piece of wax.) Quote
Contributing Member HideShop Posted December 24, 2011 Contributing Member Report Posted December 24, 2011 I only wax the tread as I'm going to use It. I would also use 100 percent pure beeswax. Beeswax will adhere to the thread better than beeswax that contains parafin or parafin. Just my way. Richard Quote
Members Sylvia Posted December 25, 2011 Members Report Posted December 25, 2011 Thanks for the link sylvia. How does this iron method compare to the Al Stohlman's way described in "Hand stitching" book? (i.e. just feed the thread through a piece of wax.) I don't know actually, I don't have that book and have never seen it. I agree with the other poster that uses beeswax though.. I would be wary of using paraffin if only because it's made from petroleum. Bees wax would be more soft and more "natural" I think. It seems to me that if you wind the thread around the cardboard box like the tutorial does, and apply heat, the wax would be more likely to absorb into the thread's fibers. I've used the drag through wax method the other poster noted but instead of wax I used soap as it was what I had handy. I found the soap to just lay on the surface and it was a bit dusty to work with... but it did stop my bad habit of using my mouth as a third hand. Blech! Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members Guapo Posted December 25, 2011 Members Report Posted December 25, 2011 I make my own wax with about 60% beeswax and 40% pine pitch. A formula I learned from Chuck Burrows. It works well. I only wax the string I'm using for the project at hand. Guapo Quote
Members Sylvia Posted December 25, 2011 Members Report Posted December 25, 2011 I make my own wax with about 60% beeswax and 40% pine pitch. A formula I learned from Chuck Burrows. It works well. I only wax the string I'm using for the project at hand. Guapo Guapo: Do you buy the pine pitch or do you go pick it off a tree somewhere? I'm curious. Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members Chavez Posted December 25, 2011 Author Members Report Posted December 25, 2011 And how do you mix them? Isn't pine pitch highly combustible when heated? Quote
Members Guapo Posted December 25, 2011 Members Report Posted December 25, 2011 Merry Christmas!!! Sylvia, I buy the pine pitch, however Chuck says he likes to harvest his own. I might someday when I have more energy. I bought a 1 pound block that will most likely last me forever. Chavez, I just shave off what I need into a small metal pot and cook it over a camp stove outside. They melt together and I pour the cocktail into little, empty, plastic, yougurt containers. Makes a block just the right size for me. No problem with flame ups. The fire never touches the pitch. It just gets the pot warm enough to melt the contents. You could use a double boiler if you have concerns. Guapo Quote
