Members Sjm1027 Posted December 29, 2011 Members Report Posted December 29, 2011 I wanted to make my first belt. Was wondering if everyone uses an oblong punch or do you simply punch 2 holes and connect the holes using an exact o knife to make a slot for the buckle and also do you trace a point on the end of the belt by hand or use a Strap End Punch? I am just curious if everyone is purchasing all these tools or doing things by hand? Thanks Quote
Members Dwight Posted December 29, 2011 Members Report Posted December 29, 2011 You can do the buckle hole (oblong slot) by doing a round hole at each end, . . . cut out the middle with a razor knife. Just remember to cut from both ends, . . . toward the middle, . . . otherwise you will go too far, . . . and slice the other end of the slot. Trust me on that one ! For the ends, . . . I just razor knife them, . . . take them to the belt sander, . . . make em pretty round or pretty pointed or pretty whatever, . . . but I do it on the sander. I also us the sander along each side to even everything up. It was $39.95 at Harbor Freight. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Sjm1027 Posted December 29, 2011 Author Members Report Posted December 29, 2011 You can do the buckle hole (oblong slot) by doing a round hole at each end, . . . cut out the middle with a razor knife. Just remember to cut from both ends, . . . toward the middle, . . . otherwise you will go too far, . . . and slice the other end of the slot. Trust me on that one ! For the ends, . . . I just razor knife them, . . . take them to the belt sander, . . . make em pretty round or pretty pointed or pretty whatever, . . . but I do it on the sander. I also us the sander along each side to even everything up. It was $39.95 at Harbor Freight. May God bless, Dwight Thanks Dwight, I'll give that a try... Already have the sander. I can already see starting at the holes and working my way inward would be best. I wouldn't have tried it but now that you mention it, it makes perfect sense. Thanks, Steve Quote
mlapaglia Posted December 30, 2011 Report Posted December 30, 2011 Another way to do it on the buckle end. From the Leathercraft tools boom by Al Stohlman Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members Sjm1027 Posted December 30, 2011 Author Members Report Posted December 30, 2011 1325285448[/url]' post='226860']Another way to do it on the buckle end. From the Leathercraft tools boom by Al Stohlman Great idea, thanks for the info.Steve Quote
