TJ Smith Report post Posted January 12, 2012 (edited) When beveling a cut line my bevel tool tends to kick back against the cut line . I align my tool with the heel in the cut, and tap with my hammer. The tool compresses the leather on the ,say right side of the cut, but also kicks back against the left side. this destroys the smooth curve of the cut line. What to do? TJ Edited January 12, 2012 by TJ Smith Quote Share this post Link to post Share on other sites
mike59 Report post Posted January 12, 2012 When beveling a cut line my bevel tool tends to kick back against the cut line . I align my tool with the heel in the cut, and tap with my hammer. The tool compresses the leather on the ,say right side of the cut, but also kicks back against the left side. this destroys the smooth curve of the cut line. What to do? TJ Hello TJ,...If I'm reading you correctly, I believe you have your tool backwards. The "Toe" needs to go in the cut line, while the heel compresses the leather away from the cut. Quote Share this post Link to post Share on other sites
Tree Reaper Report post Posted January 12, 2012 (edited) You may not be tipping the tool so that only one edge of the tool is touching the leather. Hello TJ,...If I'm reading you correctly, I believe you have your tool backwards. The "Toe" needs to go in the cut line, while the heel compresses the leather away from the cut. Edited January 12, 2012 by Tree Reaper Quote Share this post Link to post Share on other sites
Tree Reaper Report post Posted January 12, 2012 https://www.tandyleatherfactory.com/en-usd/Basic-Carving-Leather-Craft-Vide.aspx George Hurst explains beveling at 6:07 into this video https://www.tandyleatherfactory.com/en-usd/Basic-Carving-Leather-Craft-Vide.aspx Quote Share this post Link to post Share on other sites
TJ Smith Report post Posted January 13, 2012 Hello TJ,...If I'm reading you correctly, I believe you have your tool backwards. The "Toe" needs to go in the cut line, while the heel compresses the leather away from the cut. Thanks for the replies. I may have reversed the names on the beveler but I have been using it the same way as George hurst. The only thing i see is I am not leaning the tool far enough over. Thanks again. I'll do some and take a pic. TJ Quote Share this post Link to post Share on other sites
electrathon Report post Posted January 13, 2012 If your bevelers are made correct you will hold the tool pretty much straight up. Most (actually all) modern Tandy bevelers are made with too little angle to them. Since they are not properly angled you have to hold the tool at an angle to compensate for the tool. What this creates is your line is not as crisp in the bottom of the cut since your tool does not really drop properly into the cut. If you look through the rack at the store there are actually some that have no discernible angle to them (seems so simple, bevel means angle, not square). So the solution. Buy some quality tools, they are expensive. Or but some junky ones and reshape them properly. Or start from scratch and grind your own tools (this is the hardest answer). Aaron Quote Share this post Link to post Share on other sites
Northmount Report post Posted January 13, 2012 Leather too wet? Quote Share this post Link to post Share on other sites
