I'm curious if anyone uses a heavy skirting leather for belts? I was thinking of trying a 10-12 oz quality Skirting.
Feedback would be appreciated!
Thanks
I use double shoulders or sides of 9 or 10 oz. split to the specific thickness. 12oz is to hard to fold over a buckle. Skirting is acceptable English bridle is good too. I do not use latigo.
Hope this helped.
Shorty, I am a saddle maker, and almost all I have around is 10 oz and up. When I make a belt, first off I skive the leather to the desired thickness, keep in mind that all of my belts are doubled and stitched so actually both sides are skived to approximately 6 oz. then glued and stitched, after I have tooled and finger carved on them. Also, in the area of the buckle and the "tongue" area where the belt holes are I also skive down a little more to allow for folding and for the tongue to pass through the buckle properly.
Hope that helps!
Bob
Hope this helped.
Busted, just wondering why you don't use latigo for belts. I make small dog harness and leads and I only order latigo or bridle leather, I've been thinking of making myself a belt with some of the black latigo leather that I have. I'd use the bridle leather but the only color I have right now is pink and I don't want a pink belt.
Hope that helps!
Bob
Found a pic (not very good,) but it demonstrates what I was talking about.
Bob
I have used it for belts but I could not get a satisfactory finish on the edge. I was probably doing something wrong so I stopped using it.
  • 1 month later...
Thanks
We have made quite a few belts using a single ply of heavy skirting. When I true up the backline on a side of skirting (we do a lot of stirrup leathers) I often have a strip wide and long enough for a heavy strap belt. These belts are very well recieved by our customers and we often sell them to guys who saw a friend of his wearing one. These belts are great for construction workers and folks who carry guns and other heavy stuff. I would caution if you cut a belt strip from a leather that does not have a firm temper, you had better double and stitch it to avoid stretching. On the single ply skirting belts we most often use a roller buckle and loop not a heel bar buckle. As far as the bend at the buckle goes, we thin it a tad right in the area to be bent and wet it a little and it works fine. I have made some strap belts as heavy as 15oz. ... Jeff
Horsewreck, aka, Jeff M. Hairgrove
