Russ Posted July 1, 2008 Report Posted July 1, 2008 russ...thanks for the tip to keep in mind...but honestly i don't understand why??...could you or someone explain please... The posts for the Chicago screws, even the short ones (3/8's? I can't remember) are a little longer than the posts for snaps or rivets. So, once the buckle end is folded over, the post length (3/8's or whatever) requires that amount of leather for it to lay flat against itself. If you don't have that thinkness of leather with the skyved part and the belt itself, there's a gap. I always forget that, and skyve it too thin It's really just an aesthetics thing, I guess. If none of this makes since, I'll dig out one of my "oops" and take a picture of it. Quote
Members sodapop Posted July 1, 2008 Author Members Report Posted July 1, 2008 thanks russ for explaining...makes perfect sense now...sometimes the littlest things can throw ya until a guys tried it...and most certainly i would of found out the hardway by over skiving & would of been cussin like a sailor then start on making another belt lol darryl Quote Darryl..."Imagination is more important than knowledge"...Albert Einstein...
Members kseidel Posted July 1, 2008 Members Report Posted July 1, 2008 All this being said.......... Snaps are still the best, and most professional way to attach a buckle to a belt and be able to easilly remove and replace it. Use good snaps and set them correctly and they will hold very well. Keith Quote Keith Seidel Seidel's Saddlery www.seidelsaddlery.com
Members andystevens Posted July 1, 2008 Members Report Posted July 1, 2008 There is 1/4" Chicago screws available from your local Tandy store. Me personally like good belt snaps I use Rome Fastener (212) 741-9779 snaps they the best and hold up extremely well, I have been using them for the last 7 years and I make on the average of 300 belts a year with very little problems. I don't want to talk bad about any company but I need to say this the snaps from Weaver, Tandy, and a few other companies that sell the segma belt snap are no good they do not last they get very weak and don't hold when used a few times that is just some of my trial and error lessons I learned and felt I should share. Quote Andy Stevens www.andystevens.net
Members sodapop Posted July 1, 2008 Author Members Report Posted July 1, 2008 thanks alot for the info keith & andy...i look into that number and give'em a call...cuz regardless what i use...i want the quality of course...sounds like good snaps have proved themselves as well & makes for an easy change out... darryl Quote Darryl..."Imagination is more important than knowledge"...Albert Einstein...
