Members Bluesman Posted February 9, 2012 Members Report Posted February 9, 2012 I just finished a belt and want to install the fancy belt tip. I have it fit to the belt, but how do I keep it on? There are two very small holes on the backside of the tip. So, I'm open what's the procedure? Thanks in advance, Jon Quote If it ain't moving and should......WD40, If it's moving and shouldn't....Duct Tape. There you have it, now fix something
dirtclod Posted February 9, 2012 Report Posted February 9, 2012 It should of come with a couple of little screws that fit flush with the buckle when their put in. Quote I'm old enough to know that i don't know everything.
Members Bluesman Posted February 9, 2012 Author Members Report Posted February 9, 2012 No screws and no threads. Quote If it ain't moving and should......WD40, If it's moving and shouldn't....Duct Tape. There you have it, now fix something
Northmount Posted February 9, 2012 Report Posted February 9, 2012 Bluesman said: 1328753708[/url]' post='233441']No screws and no threads. Are either of the holes threaded for a screw? If so, there should have been at least one small pointed 'grub' screw. If no holes threaded, I'd look look at using epoxy on the flesh side. Test on a scrap to see if the epoxy bleeds any color through to the grain side. Anyone else with a solution? CTG Quote
Members Bluesman Posted February 9, 2012 Author Members Report Posted February 9, 2012 On 2/9/2012 at 3:04 AM, northmount said: Are either of the holes threaded for a screw? If so, there should have been at least one small pointed 'grub' screw. If no holes threaded, I'd look look at using epoxy on the flesh side. Test on a scrap to see if the epoxy bleeds any color through to the grain side. Anyone else with a solution? CTG Looked closer, threads. Now I need to find the grub who has my screws. Thanks Jon Quote If it ain't moving and should......WD40, If it's moving and shouldn't....Duct Tape. There you have it, now fix something
Ambassador Luke Hatley Posted February 9, 2012 Ambassador Report Posted February 9, 2012 If the buckle set came from tandy they have a package of screws to sell you. this has happened to me before. Quote Luke
