Willbury
Noobie Question (Spots Appearing After Moulding)
Hello,
This is my first time posting here, although I trawl about this forum regularly and pick up lots of great information.
I have been experimenting with moulding over the last while and have noticed that I am frequently getting these little dark spots appearing in the leather after taking the piece out of the mould. The leather looks totally clean and clear of spots before it goes into the mould. I have used moulding leather from both Herman Oak and Wickett and Craig and it's happened with both. Is this normal? I have attached a picture to illustrate what the spots look like. Oh and I have been using hardwood moulds that are waxed so as not to take in water.
Cheers,
Will
post-12235-079090300 1329190763_thumb.jp
I could be wrong, but it looks like the leather picked up a little iron contamination somewhere. A little invisible speck of rust can cause that to happen. There are some expert molders on the site, I'm sure they'll be along shortly with some pointers and will have a few ideas on how to keep it happening again.
Nice molding job, by the way. Future cigar case maybe?
Hmm interesting, if that's what's causing it I wouldn't be too surprised. I'm sure there are lots of small bits of iron laying around my shop, I build steel bicycle frames as part of my living.
Thanks for the praise of the moulding, it's for pens/pencils on the inside of a sketchbook case. I'll post up some pictures when it's finished.
Hello,
Cheers,
Will
Pretty sure Winter Bear is right about the iron/steel filings being the culprit. I've got that t-shirt too, it's one of the pitfalls of a mulitpurpose shop/work area. The good news is a little oxalic acid/wood bleach or maybe lemon juice will remove those pretty quick.
Bill
Hi Bill,
Thanks for the tip. How should I apply the the oxalic acid/wood bleach? Just wipe a little bit of it over the affected area?
Will
Bill
Hate to butt in but I have been wondering for some time now if vinegar would work since Lemon Juice might work?
Bumping this up. I have spots all over my leather like this.didn't notice until I got it wet and formed it for a saddle seat. Could it be hard water? I don't think I have any iron or steel in my work area. Anyone know about the lemon juice trick? When and how to apply effectively?
I have never tried vinegar - might work, but is also the carrier for vinegaroon which is iron soaked in vinegar to MAKE a black dye effect so I'd be a bit doubtful. Lemon juice works straight, but I have found you need to work the whole piece or I'd get spotting where I used it. I use oxalic acid on big pieces and sponge the whole piece when I am done and before finishing.
Sources of the iron can be your water. I used to fill my dunk tub from an outside spigot. Lived with spots all the time. Water from the house and I never spotted. Outside spigot had enough rust in the pipes to do it I guess.
I get water out of my base ment faucet. I'm not sure if that's before or after it goes through water softener, but probably doesn't matter. Perhaps I will try water from bath tub for a while
I agree with WinterBear...it's metal.
Like Bruce says lemon juice or oxalic acid will do the trick,. If you can't find the source of the metal, it may also be the beginning of mold, in either case, it will clean off with the use of the mentioned ingredients. Bob
