Members hobageeba Posted February 18, 2012 Author Members Report Posted February 18, 2012 Holy smokes, that's a whole lot more than just the red spots!! I guess hitting all these spots becomes second nature after you've done it for a while. Thanks for addressing the bobbin issue...I definitely had it going the wrong way! The bobbin goes in so it turns counterclockwise. Oil anything w/hole & open the cover over the needlebar & oil all the pivoting joints in there too. Also oil the outer part of the bobbincase everytime you go to use the machine & or everytime you replace the bobbin. Open the top cover just to the left of the handwheel & you'll be able to see the raise part w/o oil hole in it . On these oiling diagrams,the oil spots are marked with arrows. Bob Quote
Members ezurcc Posted November 5, 2013 Members Report Posted November 5, 2013 Hello everyone, I'm new here and was needing help adjusting the bobbin tension on my Consew 226R-2 also. The manual I have must be the same one hobageeba has. It instructs you to turn the screw near the center of the spring... I have removed the bobbin and do not see anything that resembles a spring. Can anyone give me a "heads up" on where this spring is? I realize this thread is over a year old, but any help would be appreciated. Thanks. Quote
CowboyBob Posted November 5, 2013 Report Posted November 5, 2013 (edited) Here's some info from a Singer manual,use screw marked "AC" for tension adjustment. Edited November 5, 2013 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members ezurcc Posted November 5, 2013 Members Report Posted November 5, 2013 Thank you, sir! How much for a copy of that manual? Quote
Members herbworff Posted July 20, 2019 Members Report Posted July 20, 2019 (edited) Realize this is an old thread, but wanted to let others know how I solved my tension release problem. Been sewing for years on my Consew 225 (bought used, great machine) without the tension release working - just pulled the thread at top to get the slack I needed. After seeing this post I discovered that my tension assembly/machine had all the parts but disc #3 that has the slot closed (gap closed in the stud) so the pin (#5) that is pushed by rod in the machine when the foot is raised will separate the discs. There are a total of 3 discs, 2 (#4) that tension the thread & the third (#3) to open them. What a dumb discovery on my part, thanks to all of you on this forum. All of you are the greatest, again thank you. Ordered a new assembly & will adjust it as described here. Herb Edited July 20, 2019 by herbworff Clarify Quote
