Members Maverick Leather Company Posted March 1, 2012 Members Report Posted March 1, 2012 Pfaff - Model # 335 - $1900 refurbished and shelved. recently serviced and made sure in excellent running condition.please email for pics. taking best offerjames.foster12@gmail.com It’s a single needle, straight stitch machine with a small diameter cylinder bed and a walking foot for top speeds of 2800 stitches per minute. The maximum stitch length is a standard 6mm. And it comes with a large table, power stand and a clutch motor available in 110v or 220v. Unison triple feed keeps layers from slipping. The needle, walking foot and feed dogs work together in unison to move the fabric after each stitch is complete. This makes for even, consistent high-quality stitching, even when using different workpiece materials together like canvas and leather. Nice roomy fabric clearance, 14mm with the presser foot raised. A moving binder attachment holds the tape close to the binding edge producing very neat bindings even on inside and outside curves. It uses 134-35 needles, and they recommend a needle thickness of 80-100 on the SCHMETZ needle system. Recommended thread type is synthetic 40/3. The Pfaff 335-G model has an extra large bobbin and 40% more thread capacity. And who doesn’t love fewer bobbin changes? The builtin winder is right where you can see it–another thing that makes life easier. You can get lots of attachments and extra accessories depending on what operations you need including welting, zippers and special binding. Work aids available include an electro-mechanically controlled thread trimmer, an automatic presser foot lifter, an automatic needle positioner. You can also get a maintenance unit for pneumatically controlled work aids. The belt comes with a finger guard, and the take-up lever has a guard as well. Stitchtype: 301 lockstitch Max. sewing speed: 2,800 s.p.m. Max. stitch length: 6.0 mm Top feed lift: 7.0 mm Fabric clearance: 14.0 mm Thread sizes: synth. up to 30/3 Needle sizes: 80 to 100 Needle system: 134-35 Clear work space: 265 mm Clear work height: 115 mm Cylinder bed diameter: 51 mm Cylinder bed circumphrence: 165 mm Weight: 40 kg (head only in carton)
Members Leathermaker831 Posted August 28, 2013 Members Report Posted August 28, 2013 Would you take 1500 for it?
