rickybobby Posted March 10, 2012 Report Posted March 10, 2012 I'm in the same boat... bought a Class 4 from Steve and he has been super helpful. Unfortunately, I'm more of a "visual" learner with ZERO experience on a sewing machine. I really with there was a good video out there to help ease the learning curve. I'm still sewing everything by hand Sixer, Stop!! Get your machine and some scrap leather, clear your mind, the machine is your friend! Some very basic steps here, glue a couple pieces of leather together like it was a holster. Sand your edges smooth so you can mark a stitch line. #1 I make my stitch line the thickness of the holster or belt. It is easy to remember and only once in a while do I deviate. It just works for me and looks ok. #2 Put the leather under the presser foot, line up the needle with your stitch line. #3 Pull 6 or 7 inches of thread out of the upper and lower and hold it taunt BEHIND the holster for the first few stitches. (this keeps everything from balling up) #4 SLOW, set your machine to very slow speed prior to doing any of this. #5 Ease your turns while sewing. A little at a time, preferably while the needle is in the leather make the turn, this takes time and a little rhythm that will come to you. #6 When finishing, before pulling the project out from the machine, make sure the needle has gone ALL THE WAY UP AND HAS JUST STARTED DOWN ABOUT 1/4 INCH. This allows the bottom thread to release from the shuttle hook and pull out of the bobbin smoothly. Also make sure the foot is in the UP position this releases thread tension so you can pull some thread out to remove the project from the machine. I have found that many people that have just bought a machine do not know #6 information. I have shown a few people this and it helped clear some confusion up. After that it is just practice. Put your hand sewing stuff away and spend a couple hours with your machine, it will enhance your leather working skills!! Ferg had a good idea about you tube, I have not looked but I bet there is some great info and basic starter sewing videos on there! Hope this helps, Rick Quote Rick
Members rccolt45 Posted March 13, 2012 Author Members Report Posted March 13, 2012 Ok sounds like good advice thanks so much. Quote
Tree Reaper Posted March 13, 2012 Report Posted March 13, 2012 I have found that many people that have just bought a machine do not know #6 information I've been running the needle to the top but I'll experiment with this, thanks Rick. What do you do when the bobbin runs out of thread, I suspect you try and stitch over, of course not running out and making sure the bobbin is full prior to starting is better. Quote
rickybobby Posted March 13, 2012 Report Posted March 13, 2012 I've been running the needle to the top but I'll experiment with this, thanks Rick. What do you do when the bobbin runs out of thread, I suspect you try and stitch over, of course not running out and making sure the bobbin is full prior to starting is better. I just pull the excess to the underside of the project and start new a couple stitches back. This is what I consider "commercially acceptable" If it is truly a "custom" item, with a custom price, I will use a new bobbin. There is another method and that is to separate the layers, pull the thread to the inside, tie it off then start the stitch in the same hole, finish the project and go back and pull the starting thread in that hole and reglue the layers together. It is a P.I.T.A. but it can salvage a "custom" piece. Rick Quote Rick
Tree Reaper Posted March 13, 2012 Report Posted March 13, 2012 Thanks Rick, I just read a little something on back stitching I wasn't aware of. I think it puts all the thread on the bottom of the project so you don't see any ends on the finished side. Quote
