To give you a little back story: I have been sewing on my Pfaff 1245-706/47-6/01 for about a year. Everything I have done has been self taught so it has been a uphill battle. My machine came with 140/22 needles that have worked great for the material I have been using. I'm now at the end of my supply of needles and order new ones what I had thought were exact replacements based on my machine and needle size (140/22).
When they arrived I noticed that they are shorter than the ones I have been using by a 1/4 inch or so. I tried one of the new needles and they do not work properly, they don't go down far enough to grab the lower thread. I have included a picture below to show the difference. The needle on the left is the needle size the machine came with and the needle on the right is the new needle. The blue package is what the new needle came out of for reference.
My question is, what needle do I need to order to get the correct length? I have scoured the forum and google looking for a definitive answer and cannot find one. Any help would be appreciated. Please excuse the ignorance
post-23507-079950800 1331231025_thumb.jp
What is stamped on the end of the size of the needle you are trying to replace? If all else fails drop the needle bar to the height of the new needle.
  busted said:
1331233071[/url]' post='238207']
Thanks for the reply.
The old need is stamped "140/22" The new needle is stamped "schmetz 22/140"
I guess my question is do they make a 140/22 that comes in different lengths?
Yes,there is many different lengths of needles that come in a #22,but you probably got 135x17 which SOME 1245's take but it sounds like you need the 190R for your machine.
Bob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Bob
Yes the new ones are 135X17 and it sounds like you may be right and I need 190R needles.
Thanks!
This manual for the 1245 should help a little.
www.mansew.com/​PFAFF/​PFAFF%​201245%20INSTRUCTION%​20MANUAL.pdf
The 135x17 will work in place of the 134-35, BUT as Bob said, they also came with the 190 needle system. Measure the needle that works for it's Butt to Eye (BTE) dimension. 44.5 mm is a 190 needle, 38.1 is the 134-35, and 38.9 is the 135x17. Sometimes a machine with a 190 needle system can be made to use 134-35 or 135-17(16) but make sure the needle bar doesn't strike the presser feet or things will go south. For heaver work, try to get the leather point needles.
Art
Thanks!
