I want to make the beveled that was shown in the video.
Could someone tell me what can be used as the brass piece?
I can't even imaging where to start looking for something like that:-)
Brass is fairly soft so if you have a dremel it shouldn't be too difficult. You could also try using hard plastic like from a cutting board too.
I used a piece of aluminum from Home Depot, a hacksaw and a drill to made the slide portion. Not too hard to make. Aluminum is very soft and easy to work with.
Hello:
Could you please post a link to the video?
S
  • 3 years later...
Why not make it from wood ??
Use a dremel to make it
I used a scrap piece of Aluminum as well - to get the shape I just filed it down a bit on the small part - seems to work pretty well, though I don't have super-fine control over it.
