Tanthathide9 Report post Posted March 21, 2012 (edited) I want to do the same as the picture shows the body is stiff but flexible and of course handle is stainless I don't know how to attach the core to the handle or if that's even necessary any advice would help thanks in advance Josh Edited March 21, 2012 by Tanthathide9 Quote Share this post Link to post Share on other sites
Aggiebraider Report post Posted March 21, 2012 Maybe the handle has a loop or eye on the end of it that you run the body strands through then cover the whole thing with a knot Quote Share this post Link to post Share on other sites
Dwing8 Report post Posted March 21, 2012 Could be it's a tube and the core is stuffed inside it? Seems like a good way to me. Quote Share this post Link to post Share on other sites
Tanthathide9 Report post Posted March 22, 2012 I can see an eye loop at the end but it's not hollow it's a solid stainless steel rod so stuffing it is not a solution in this case however it could be a definite possibility if it were tubing Quote Share this post Link to post Share on other sites
The Major Report post Posted March 22, 2012 There has to be some hole going through it somewhere. It may even be a small hole (1/4" maybe) to put the core through and plait on top of it. Otherwise there is nothing to hold the plaiting onto the handle. I do something similar with my whips, but I usually cover the handle. I start with a 6" stainless nipple. I use an 1/8 piece of round nylon rope and start plaiting my core about 6" from the end of the rope. I'll plait 4 layers at varying lengths to start my taper. then once I am about the diameter of the inside diameter of the nipple, I will insert the core. I will tie some small washers along that rope end that I left un-plaited. Now I cap off the end of the nipple, fill it with epoxy, and insert the core. wipe off the ooze, let it cure, and now I have a nicely weighted solid handle with a rock solid core. I should mention the cap I use is a perfect foundation for the butt knot. Quote Share this post Link to post Share on other sites
