I read with interest the post about the Veach buckles. I really don't like Blevins style buckles for most of the reasons stated in the thread about Veach buckles.
So if you don't want Blevin's, what are some good alternatives?
"Remember this day...for it is the doom of men that they forget." ~ Merlin, Excalibur
Most of my customers prefer Superior stirrup buckles, and I change a lot of blevins out for them. Hope this helps. Ken
I vote for Superiors as well...I only keep Blevins buckles in the shop for someone that might need a set replaced.
Edited by Elton Joorisity
"If you see your stirrups slap together above the saddle horn, you're probably bucked off"
Dave Stamey, The Bronc Ballet
The superior buckle is great because you can retro fit them on any saddle that has 3 inch blevins without having to repunce the adjustment holes. You can see these buckles on Panhandle leathers site or in the Weaver Leather Supply catalog. They don't have a slide so you won't have moisture problems, plus with the stainless steel construction you don't deal with that aluminum yuk that blevins have. Blevin does make a brass buckle, but you still have the slide plus the brass blevins cost more than the superior buckles. The Veach buckles are great but I have not been able to get a good supply line for them. Long story short go with the Superior... Jeff
Horsewreck, aka, Jeff M. Hairgrove
  • 2 months later...
Anyone know how well the Superior buckles work with a Nevada twist? Do you need to keep replacement plates on hand? They look kind of easy to lose.
Thanks in advance,
Buck
Buck,
They'll have a 3/8 or so string on the plate, weave it through the first three or so holes below the buckle and it won't fall off. I've used them for years both with and without a twist and haven't had one come apart yet.
Best regards,
Josh
Thanks Josh
  • 3 months later...
I'm interested in these Superior buckles, too. Anyone have a pic of them on the leathers so I can understand how to retrofit my saddles? I'm just not seeing how you can use the same holes made for Blevins. Wouldn't it be lopsided?
Thanks
If you buy a set they come with an instruction sheet. Most likely you will have to trim off the fender leg and punch new holes. You only lose an inch or so. Its not a big deal.
Sonny Felkins at Quality MFG is dealing in them now and he has the best prices I have found. He doesn't have a website but his number is 435-587-5070.
CW
1 Thessalonians 4: 11,12
Thanks. Now I REALLY want to see a pic LOL I have a saddle with damaged leathers that I'm going to either have to jerry rig or replace. What side of the fender part generally gets the shave? You talking the top part where the blevins would have sat?
