Members Glendon Posted April 13, 2012 Members Report Posted April 13, 2012 Hi all, I just picked up a 1 ton arbor press on the cheap to take over some stamping and eyelet / rivet setting. Thing is, it of course came in packing grease. I don't have any real experience maintaining bench tools like this. I've only ever borrowed them for quick projects. How do I clean this stuff off? Would soap and water do the trick or do I need to get break cleaner or gun cleaner or something that some woodworking forums have suggested? Quote
Members Bluesman Posted April 13, 2012 Members Report Posted April 13, 2012 Get a spray bottle of Simple Green and a pile of rags. No water. This stuff will cut grease. Spray it down and have at it. Post pic too. Quote If it ain't moving and should......WD40, If it's moving and shouldn't....Duct Tape. There you have it, now fix something
Members Sylvia Posted April 13, 2012 Members Report Posted April 13, 2012 Any grease cutting cleaner should work, even that mechanics hand cleaner, or oven cleaner. I would apply the cleaner and let it sit a bit then wipe. (in other words let the chemical do it's job) Have fun! Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Northmount Posted April 13, 2012 Report Posted April 13, 2012 Stay away from harsh acidic or caustic chemicals that will hasten the corrosion process if left on very long. I would say no to oven cleaner. If the more green friendly cleaners don't work for you, then use petroleum based solvent or mineral spirits. No gasoline, but can use diesel or kerosene in a pinch. Remember vapors for most of these solvents are not good to breathe and are inflammable (explosive in right proportions with air). So well ventilated space with no ignition source, like the pilot on a heater or furnace. CTG Quote
Members Glendon Posted April 13, 2012 Author Members Report Posted April 13, 2012 Thanks everyone. I'll pick up a bottle of Simple Green and try that first. The grease isn't on too too thick, so it should work. I'll post a before and after pic for the future reference of anyone who comes across this thread later. Quote
