Members kagekeeper Posted April 19, 2012 Members Report Posted April 19, 2012 I'm wanting to make a tool bag for my lil brothers HD and am in need of some patterns. I want to tool a gargoyle on front flap so need said flap to be pretty large and unobstructed so the bag itself would b slightly larger than the regular . any ideas and input are appreciated. The more simple the better...lol Quote
Members shadowryder Posted April 19, 2012 Members Report Posted April 19, 2012 Go 12 inches wide by 6 inches deep,then you want 3 inches front to back, make it a U shape with a flap coming from top back 3 inches over then 4 inches down the front, SO your main piece of leather is gonna be12 inches by 22 inches, your 2 side pieces are gonna be 31/2 inches wide by 6 inches plus another 4 inches for an intenal flap so 31/2 inches by 10 inches times 2. the extra 1/2 inch on the sides gives you room to punch holes for stitching or lacing. put all thes measurements down to card or thick paper and cut out to give you a good idea of what you got before you start cutting leather. hope this is of some help to you, I normally make round tool rolls but these are not very good for carving/tooling the U shape is better for that, Quote
Members benlilly1 Posted April 20, 2012 Members Report Posted April 20, 2012 That's a real nice looking tool roll Shadowryder! Quote
Members shadowryder Posted April 20, 2012 Members Report Posted April 20, 2012 That's a real nice looking tool roll Shadowryder! Thankyou very much,I love that mexican round braid but it is a real long job doing a roll with it and pretty tough on the fingers so looking for other lacing techniques i could use as well.that would look right on the piece. regards JJ. Quote
Members jayjay Posted May 3, 2012 Members Report Posted May 3, 2012 The lacing looks real good and i have a question about it. What size lace 1/8 or ? and do you space your holes the same distance as the width of the lace? When I do the round lace I never seem to get it look as tight as yours. Thank you Thankyou very much,I love that mexican round braid but it is a real long job doing a roll with it and pretty tough on the fingers so looking for other lacing techniques i could use as well.that would look right on the piece. regards JJ. Quote
Members shadowryder Posted May 4, 2012 Members Report Posted May 4, 2012 The lacing looks real good and i have a question about it. What size lace 1/8 or ? and do you space your holes the same distance as the width of the lace? When I do the round lace I never seem to get it look as tight as yours. Thank you Hi, thanks for the compliments on my lacing,Because the tool roll is a fairly large item I.E. 12"long x 5" diameter I have used a 5MM{3/8ths} lace with the holes punched at the same size and the wheel i use does 6 holes to the inch so yeah they will be aprox 3/8ths apart,I use the brass Jumbo Perma Lok needle with the screw in end for the lace but i have tapered it to a point for easier access to the holes. Though i will say its a real PITA doing those end pieces n getting all the holes to line up properly LOL!! I hope this helps you in some way and look forward to seeing some of your work, laters, JJ Quote
Members jayjay Posted May 4, 2012 Members Report Posted May 4, 2012 Thanks for the info. I will try that out. Where do you buy your lace? I can only seem to find 1/8 or 5/16" lace. Thanks Hi, thanks for the compliments on my lacing,Because the tool roll is a fairly large item I.E. 12"long x 5" diameter I have used a 5MM{3/8ths} lace with the holes punched at the same size and the wheel i use does 6 holes to the inch so yeah they will be aprox 3/8ths apart,I use the brass Jumbo Perma Lok needle with the screw in end for the lace but i have tapered it to a point for easier access to the holes. Though i will say its a real PITA doing those end pieces n getting all the holes to line up properly LOL!! I hope this helps you in some way and look forward to seeing some of your work, laters, JJ Quote
Members Cyberthrasher Posted May 4, 2012 Members Report Posted May 4, 2012 Thanks for the info. I will try that out. Where do you buy your lace? I can only seem to find 1/8 or 5/16" lace. Thanks Springfield will do 1/4", but you have to call or email for it. I've heard lots of good things around here about y-knot too, just haven't ordered anything from them yet since I've always been able to get it from Springfield for about the same price. http://y-knotlace.com/ Quote
Members paws Posted May 8, 2012 Members Report Posted May 8, 2012 one thing I do on my toolbags to get the holes to line up for the braiding is.... I wet the leather 'ends', then use pop rivets (aluminum) to line up all the holes, the next day, after it drys I lace up the bag. It makes my Mexican Round braid go way smoother.... you might want to give it a try.... Quote
