Members jlaudio29 Posted May 1, 2012 Members Report Posted May 1, 2012 What are you all using for the metal support that i always see on thumb breaks. that little metal strip plate. Or if there are any other methods im open to ideas. Quote
Members troop Posted May 1, 2012 Members Report Posted May 1, 2012 (edited) i use the metal clips from this supplier. you have to order minimum 500 pieces. but well worth it. http://www.jrmclips.com/ Tony Edited May 1, 2012 by troop Quote The hand that feeds you also puts the chains around your neck.
Members camano ridge Posted May 1, 2012 Members Report Posted May 1, 2012 High Dessert Leather sells them 10 for $7.00. http://www.highdesertleather.com/id74.html Scott Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
Members glockanator Posted May 1, 2012 Members Report Posted May 1, 2012 I was given some steel strapping.off a pallet. Just.cut.it.to size drill holes and attatch attatch. Quote
gringobill Posted May 1, 2012 Report Posted May 1, 2012 I've been making my own out of 16 ga steel that I cut in 1/2" strips, then cut to the length I need , round the ends on grinder and belt sander and drill holes. Pretty easy and pretty cheap. Quote
Members Eaglestroker Posted May 1, 2012 Members Report Posted May 1, 2012 Ive used a few things. Kydex works pretty well too. Old bandsaw blades work fairly well. Quote
RMB Custom Leather Posted May 1, 2012 Report Posted May 1, 2012 (edited) I have used Kydex and made my own metal ones but I now buy them in bulk. I have alot in stock if you haven't found some, click below if you want to take a look. Edited May 1, 2012 by RMB Custom Leather Quote Thank you, Rob Bennett Email: rob@rmbcl.com Authorized Distributor BLUEGUNS Multi Molds Maker Supplies Home of the "Taco Press" kydex/Leather former FREE SHIPPING! FACEBOOK
Members Bronson Posted May 2, 2012 Members Report Posted May 2, 2012 I've made my own out of stainless steel but for the hassle it's easier to order the stainless steel ones from High Desert Leather. Bronson Quote
Members NoName Posted May 3, 2012 Members Report Posted May 3, 2012 +1 for Glockanator's answer. Quote Diapers and Politicians should be changed often... Both for the same reason!
