I ended up going with a combination of clean industrial sewing machine oil and brake cleaner. I used clean oil to soak and lift off any loose gunk, and then blasted the troubled area's with Brake Cleaner and an air hose. Afterwards, I used fresh clean patch's soaked in oil to wipe down all surfaces, and fresh dry patch's to wipe off any excess oil. I then oiled all the galley's and wear surfaces, let it sit and soak, then re-oiled and wiped excess off.
It turned out really well.
Now I have to figure out how the bobbin winder works surrender.gif and make a new top, and we'll be set.
Edited by mogwild
  • 3 weeks later...
Have you ever used "Brake free CLP" (Cleaner, lubricant, and preservative) for guns?
Gun blast is basically brake cleaner as far as I know and I use it on my firearms, but I also use CLP. The CLP is a cleaner and lubricant in one. I would think brake cleaner to get stuff out, a quick spray of CLP to everywhere would give a general all around lube, and then drops of oil in key places to finish it off.
Does anywhere actually need "grease?"
Edited by ChimeraKennels
Yes, I use G96 as well, but I wanted to use genuine industrial machine oil for this project, maybe my next one I'll try the CLP or G96.
I can post up some pictures now that the top is done and the machine is all cleaned up, should I do that here or in another thread?
If you want to show photos of how well the machine was degreased, post here. I would start a new topic to show off your continuing work on it.
Posted IMHO, by Wiz
Clarification...When I said I use CLP, I was referring to my firearms. I have no idea if the oil in it is compatible to sewing machines...and meant for that to be a question. Sorry if I implied otherwise.
