Members ericluther Posted June 2, 2012 Author Members Report Posted June 2, 2012 needle and tension. I ordered some round point #18 from Steve so I could sew thinner stuff. No they aren't designed for it but I have and still use it to sew thin stuff. I have sewn 2 layers of lamb with my class 4. try smaller needle and thread. When I got mine my smallest needle was a #23 that I used with 138 thread. Also play with the tension to pull the knot in to the middle of the leather thanks Scary, I am going to need to sew two pieces of lambskin, do you recall needle and thread weight you used. how much tension adjustment did you have to do? Thanks!!! Eric Quote http://lutherdesigns.com/ http://www.facebook.com/LutherLeather
Scary Leatherworks Posted June 3, 2012 Report Posted June 3, 2012 thanks Scary, I am going to need to sew two pieces of lambskin, do you recall needle and thread weight you used. how much tension adjustment did you have to do? Thanks!!! Eric I started with the 138 thread and had some ok results but was then reccomended to switch to an 18 round point needle with 69 thread. haven't tried that yet was a bit of tensioning to work out had to back it off quite a bit due to the softness of the leather. make sure you try multiple scrap trials to get it right. Quote
Members frmntx Posted July 17, 2012 Members Report Posted July 17, 2012 I started with the 138 thread and had some ok results but was then reccomended to switch to an 18 round point needle with 69 thread. haven't tried that yet was a bit of tensioning to work out had to back it off quite a bit due to the softness of the leather. make sure you try multiple scrap trials to get it right. I had the same problem with mine, I lightened the top tension, and tightened the bobbin (1/4 turn at a time, lol) and it worked itself out. Hope this helps! Quote
Members PanioloBrian Posted August 25, 2012 Members Report Posted August 25, 2012 use lighter thread for sure and it will help, this means smaller needle also. I sew 2/3 oz to itself folded over on pocket knife scabbards and no problems. Its better on heavier leather but until I have a machine for every leather I build things from its just my Class 4 from Steve. Quote
Members Bobby hdflame Posted August 29, 2012 Members Report Posted August 29, 2012 I just got my Cobra yesterday, so I can't give you a lot of advice on it specifically, but from the picture your top tension is too tight. It's pulling your bottom thread all the way to the top. Using a smaller needle/thread combo like the 138/22 needle will help on your thinner leather. Until you get some more needles and smaller thread, try just backing off your upper tension a half turn at a time on each knob while running a short test stitch. See if that doesn't help get your bottom thread back down inside your leather. Until now, I've been using a Highlead heavy duty walking foot machine. I rarely have to adjust my bobbin tension. I can just about always get my tension correct by just adjusting my top tension. Unless you know what you're doing, you can really get things screwed up by over adjusting your bobbin. If you go from the 277 thread down to a 138, you'll most likely HAVE to adjust your bobbin tension. Good luck. I'm off to play with mine! Quote Bobby Riddle Sanford, NC www.riddlescustomupholstery.com www.sunstopper.biz
Members Spinner Posted August 29, 2012 Members Report Posted August 29, 2012 For thinner leathers you can also try using a Tri-point needle instead of a ball or knife. The advantage is the tri is still sharp so it will pierce nicely but it creates a smaller hole than a standard LR needle. Another thing I have learned from looking at other folks work is generally as you go down in thread size you should also consider shortening the stitch length for appearance & strength. The Tri-points aren't as easy to find but usually will have TRI or NW at the end of the numbers. Balls don't add anything and a bladed needle usually has a LR at the end. (ex. 135x17LR) Quote Chris Three Mutts Customs Leather - http://www.threemuttscustoms.com
