Members jamco5 Posted November 15, 2013 Members Report Posted November 15, 2013 OK here ya' go. You might need to make the 3/8ths inch plate 1 1/2 inches longer I had to install a 3/4" spacer on the table in order to have clearance for the belt to fit around the 8" pulley. I milled the face of the smaller pulley to bring the vertical centers of the two pulleys closer. It ended up 1/16inch clearance for the machine belt to the side of the 8" pulley and I drilled the nut and bolt and put a cotter pin through it to hold everything in place.The new belts were the most expensive part of the project. Hope this helps. CustomDoug, on 22 July 2012 - 12:19 AM, said: Busted - you couldn't post a picture of that set up, could you? Attached thumbnail(s) Hi busted I to managed to use some old parts around the house and made a speed reducer, but now I need another. I could do the same thing that you have done but I think you have done one thing I can't , as I can do no milling and we do not have a local machine shop anymore. Did you mill out the shafts and put sealed bearing in and did you pin the two pulleys together? Please correct me if I'm wrong and if you could suggest a way I could do this, please explain because your setup is great. Quote
CowboyBob Posted November 15, 2013 Report Posted November 15, 2013 I've seen the same type of pulleys in a dryer(clothes) if you have any scrap yards around you might want to check as they have a nice sealed bearing too. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Gregg From Keystone Sewing Posted November 11, 2016 Members Report Posted November 11, 2016 On 7/17/2012 at 3:55 AM, Pinsplitter said: thanks for that info. i did actually find a pic of a speed reducer. $145 plus shipping to Aus and waiting was too hard, so i made one myself......!! Ha, that's great, and I'll bet works very well. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
