Members johnggrg Posted June 17, 2012 Members Report Posted June 17, 2012 I am trying to use some black eyelets on a project. I have been testing some on scrap leather first because it's the first time I have used them. My problem is after I set one the black paint is scraped off and the brass shows. How can I prevent this from happening? John Quote
Members johnggrg Posted June 17, 2012 Author Members Report Posted June 17, 2012 Has anyone had this problem????? Or am I the only one? John Quote
Members scottishshoemaker Posted June 17, 2012 Members Report Posted June 17, 2012 You may have the wrong setter or it may be marked, hence the paint coming off. If they set ok then just paint the bit that shows brass with similar paint. Hope it helps. Quote
Members Nick69 Posted June 17, 2012 Members Report Posted June 17, 2012 A small piece of kid lining or other thin leather put between the eyelet and the tool can help. It has to be thin though. Quote
Members johnggrg Posted June 18, 2012 Author Members Report Posted June 18, 2012 Thank you for the replies. It is the right setter. And it does set fine. I tried a piece of thick plastic tape on the eyelet and it did not scrap the paint off. Only tried it on one so far. I will try it on a few more and report back to say weather it worked or not. John Quote
Members jinyuli Posted June 23, 2012 Members Report Posted June 23, 2012 you should use a die set to attach the eyelets Quote
