Members Grabagear Posted July 24, 2012 Members Report Posted July 24, 2012 So I was asked to make a g21 pancake holster. But I only have a g17. I looked up the specs. The g21 is 3 mm wider 1 mm taller and a few mm longer. Do u think molding the g17 not so tight ' would be OK for a tight fit g21 holster? Or should I not even try it? Thanks a lot for the help! Quote
Members renegadelizard Posted July 24, 2012 Members Report Posted July 24, 2012 So I was asked to make a g21 pancake holster. But I only have a g17. I looked up the specs. The g21 is 3 mm wider 1 mm taller and a few mm longer. Do u think molding the g17 not so tight ' would be OK for a tight fit g21 holster? Or should I not even try it? Thanks a lot for the help! It wont fit..3mm wider and 1 mm taller is the problem...longer you can get away with, but width and height you cant fudge. Quote
Members chiefjason Posted July 24, 2012 Members Report Posted July 24, 2012 9MM, .40, and .357 sig Glocks are the same dimensions, other than slide length differences. .45 is certainly bigger. Quote
Members Sixer Posted July 24, 2012 Members Report Posted July 24, 2012 Try it. Move your stitch line by the slide out by 1/8th in. Don't mold it super tight. It will work just fine. Ask me how I know Quote
