I just finished a Tandy purse kit and the final step was to fold over the top flap.
Bloody thing cracked across the top!!!!
I cased (Peter Main method), carved and tooled. Then dyed using the new Tandy Professional waterstain. Applied a light coat of neutral leather balm with atom wax. Antiqued with Feibings antiquing. After dry I laid down 2 very light coats of 50/50 diluted Resolene with a airbrush.
Next day, put on a couple of coatings of mink oil paste on the flesh side of everything. Then assembled.
All looked and felt great until I bent that flap over.
Anyone have any clues as to why this might have happened? Personally, I'm thinking old, dry leather and that I should have maybe used NFO... but I didn't want to darken it.
Clues? Ideas??
Did you get the leather wet before you folded it over?
~Cheryl
There are many things in life that will catch your eye,
but only a few will catch your heart...
pursue those...
After tooling its always a good idea to oil the leather to replenish the oils that are removed by casing and tooling. Olive oil of Neetsfoot oil are some of the best things to use. Lexol is also a good choice. The Leather balm with atom wax really isnt any good to replenish the leather and keep it soft and supple. It is also a good idea to set the main bend area with the leather damp so it can stretch rather than crack. Did the leather crack or was it the finish that cracked? Resolene can crack if its on too thick.
If it was the leather than even old dry leather will be usable if you treat it with neetsfoot oil or olive oil before you bend it. On old leather I treat it with neetsfoot oil, then tool it and then give it another coat of neetsfoot oil before I start with the dye and finish.
If you do not want to darken the leather than use olive oil or Lexol conditioner. Neither will darken the leather as much as neetsfoot oil.
What was the purpose of the Mink oil paste?
The key to immortality is first living a life worth remembering.
Bruce Lee
Nope. It had dried, been dyed, antiqued, waxed and oiled from the back with mink oil.
I didn't know how wetting the interior would affect all of the finishing on the front. Especially since it had already had the mink oil applied.
Lightly spraying the flesh side along the bend line normally does not affect the finish as you are not getting it that wet.
Sounds the biggest mistake was not making the bend before the finish. Its always best to make sure all the bends and fits work correctly before applying the finish. I personally think mink oil is for squeaky minks and not leather but that is a personal opinion. Other people love it.
Can we see a picture of how bad it cracked? maybe there is a fix.
Edited by mlapaglia
Bruce Lee
Well, I feel the Resolene was not the cracking item. I dilute it 50/50 with water and I used a mist type spray from my airbrush. Let it dry and made a second light coat. I looked like the leather actually cracked.
I've used NFO before but usually on belts that are darker shades. I have some Lexol 4-way but haven't done much with it so far.
I mainly use the Leather balm applied like a block dye, as a top sealer to block the antiquing from darkening the leather. I only want it (antiquing) in the impressions. Although it does do a little softening, it's mainly on the surface from my experience.
I guess I need to play with the NFO some more and see how it works first hand. I've never even heard of oiling before tooling!. How does it affect the water used for casing?
As for the mink oil paste, it's mink oil in a paste form. The mink oil liquid, like the NFO, can easily be applied too heavily and change the color or shade of the leather. The paste form makes it much easier to apply the oil evenly and consistently. I mainly use it on my collar, leashes, belts, bracelets and other strap try products. It takes a stiff strip of finished leather and makes it soft and limp as a noodle....
Wh`at about wetting after all of this is done. is it recommended? How wet... won't it affect the dye/stain??
I only suggest oiling before tooling when the leather is REALLY old and REALLY dry. Normally its done after tooling and before dying.
If you wet lightly before you bend you should have no problem. The point is to do it before you dye and finish. This way the leather is all stretched and ready for its normal posistion. I ofter do any bending right after the tooling while the leather is still cased. That way it does not have to be wet again. It all depends on how you want to do it. Just remember that one of the last things you normally do with a project is dye and finish. Burnishing the edges is in that part too.
Bruce Lee
LOL Squeaky Minks. :thumbsup:
A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Let's see if I can get a couple to stick here
post-14889-050148100 1344658814_thumb.jp
post-14889-030138800 1344658815_thumb.jp
post-14889-011045400 1344658816_thumb.jp
Ouch. That is bad. You could replace the entire piece or make a piece that would
cover the cracked section. Tool it up nice so it fits with the rest of
the purse. Your other option is to deglaze the entire piece and redye
it so the dye gets in the cracks. The best option I know of is to replace that panel.
Hopefully someone will have a better idea.
If it was my product I'd cut the flap off before the. Bend and sew a new piece to the back.
Maybe do a decorative cut on the edge so it looked good and dyed it like the rest.
Problem is if it looks like carp the you have to replace the entire piece.
We all have things in the scrap box that still hurt to look at. I have a holster
that was almost done and I noticed I had forgotten to sew a clip holder in place.
No way to fix it but start over. 3 hours and a great piece of leather shot to heck.
If that is a Tandy kit take it back and get them to rea e the leather if you purchased
It reciently.
Bruce Lee
