Members Blazin Posted August 23, 2012 Members Report Posted August 23, 2012 Designed this for a guy and finally got it finished. Hadn't felt like working on it after a bad wreck we had and so the customer had to exercise some serious patience. We put the finishing touches on it today. This main pocket of the pouch also contains a sheath built to hold the Lesche digging tool and and outer sheath for the Garrett pinpointer metal detector. Outer pouch is for valuable finds such coins, jewelry etc. Don't know why but this project was work. Still trying to get my corners right after wet forming a pouch. I have trouble with that. Quote http://www.leathersheaths.net/ http://www.facebook.com/GillsCustomLeather
Members David8386 Posted August 24, 2012 Members Report Posted August 24, 2012 Do you wet form over an object like a wood block? Or just use a bone folder? I have used a block for some bag ends but they did not have 90 degree corners. I still think that it came out good. I am still reading books and tutorials and have at least figured out that it is not quite as easy they make it look. David Quote
Members Blazin Posted August 24, 2012 Author Members Report Posted August 24, 2012 Yes David I wet formed both pouches over blocks of wood that I built. The problem I have is afterwords bringing the corners together and cutting the material so it fits ok. That small pouch came together nicely but the larger one that it rides on does have some tiny gaps down at the bottom. However in this application it was fine because it will allow dirt and debris to fall out of the pouch. Quote http://www.leathersheaths.net/ http://www.facebook.com/GillsCustomLeather
Members c2369zulu Posted August 29, 2012 Members Report Posted August 29, 2012 Looks great!! Just a thought, but why not cut the length of the "sides" (not including stitch area) of the pouch longer so the longer portion at bottom folds inward like a cardboard box and have the main flap and "bottom side" of the pouch (where you stitch it on) be one piece that folds around the side flaps, inside along the backing plate then up and over to create the flap? I'm sure this made no sense, but its hard to describe in words ....... Quote
Members Dirck Posted August 30, 2012 Members Report Posted August 30, 2012 I don't cut the corners after forming over a block. I re-wet while still on the block and bone the crap out of them to get them down tighter. I still end up with an external pooch, but getting better. Sometimes I leave the pooch and sew over it. For electronics, I think it pads the corner if dropped! Quote
Members Dirck Posted August 30, 2012 Members Report Posted August 30, 2012 Blazin, I think there is a usefulness to the open corners on a work rig like that! It probably makes it easier to clean if the guy's puttin dirty tools in it. By the way, the folded over top on the big pouch is very nice. Quote
Members Blazin Posted August 30, 2012 Author Members Report Posted August 30, 2012 On 8/29/2012 at 6:51 PM, c2369zulu said: Looks great!! Just a thought, but why not cut the length of the "sides" (not including stitch area) of the pouch longer so the longer portion at bottom folds inward like a cardboard box and have the main flap and "bottom side" of the pouch (where you stitch it on) be one piece that folds around the side flaps, inside along the backing plate then up and over to create the flap? I'm sure this made no sense, but its hard to describe in words ....... Thanks for the post and idea! That is what I was going to try and do with both pouches, however I hand sew and it would be next to impossible being that I use a saddle stitch on all the gear I make to get my hand inside that smaller pouch to finish the sewing. Maybe I'm missing something though. Quote http://www.leathersheaths.net/ http://www.facebook.com/GillsCustomLeather
Members Blazin Posted August 30, 2012 Author Members Report Posted August 30, 2012 On 8/30/2012 at 6:07 PM, Dirck said: Blazin, I think there is a usefulness to the open corners on a work rig like that! It probably makes it easier to clean if the guy's puttin dirty tools in it. By the way, the folded over top on the big pouch is very nice. Thanks Dirck, the folded over top of the pouch is actually oil tanned leather that I stitched onto the regular tooling leather to give it a nice smooth and bold rounded look. I really love the oil tanned leather for lining the backs of sheaths and other stuff but man is it expensive! Quote http://www.leathersheaths.net/ http://www.facebook.com/GillsCustomLeather
