I use 4 oz or so veg tan in my bullet loops, . . . do not sew them, . . . loop out and back through the same hole. Rivets hold the ends, . . . and it is always contact cememted to the liner.
Always do em wet, . . . use actual bullet for sizing, shaping, etc.
I use a 7/8 in wide strap pulling through a 3/4 in strap punch hole, . . . have never had any problems with it.
Sometimes the first few loops are a bit tough, . . . but after it dries, . . . gets dyed, finished, etc.. . . they always look good to me, . . . customers are happy.
Works for me.
May God bless,
Dwight
Thanks Dwight! That's sounds like a unique way of doing them. Do you leave the bullets in place until it dries, then glue the liner on before removing the bullets?
I assume that doing it wet pre stretches the leather?
I haven't made a Western holster yet but have been watching the video by John Bianchi. He shows sewing them with a rivet or concho on each end, ending the bullet loop on the back side so the end doesn't show.
Is there a benefit or advantage to the way you do it over sewing? I just got my new Cobra, so I'm not hand stitching if that's the advantage. Thanks again.
Edited by Bobby hdflame
Bobby Riddle
Sanford, NC
www.riddlescustomupholstery.com
www.sunstopper.biz
As far as the bullets go, . . . I usually pull them all out after I have riveted down both ends. By that time, . . . the sizing, forming, etc. has all been done, . . . and most of the stretching/shrinking has also taken place.
I come back after dyeing & finishing and re-insert the bullets to make sure nothing has changed. Invariably, one loop will have tried to shrink on me, . . . but that is usually the worst.
As far as advantage, . . . just a personal note, . . . I wouldn't give anyone two whoops for a sewn cartridge belt. I've owned em in the past, . . . doubt that one will ever grace my place again. I also refuse to make them for my customers. When they see my personal black rig, . . . that is usually enough, . . .
And, . . . I can usually do a 24 loop section of a belt in just about 45 minutes, . . . that is from a blank belt back and piece of loop strap, . . . to a cartridge belt, punched, looped, and riveted, . . . drying so it can be finished up.
May God bless,
Dwight
www.dwightsgunleather.com
Loop out the back through the same hole??
Having trouble picturing that Dwight. Are you say you do not sew between each loop?
Jake
Works for me.
May God bless,
Dwight
Once you know what the magician know.... it isn't magic anymore.
You can look on this post, . . . and see every stitch I put in my belt loops.
Look at the enclosed pictures, . . . these are my 3D note pads I refer to when I am making a cartridge belt.
At 67+, . . . somethimes the memory ain't worth a dime, . . . so I have cheaters. These are mine. This is how I do it.
Yep, . . . the little ones are for .22's and the big ones are for .44 or .45.
May God bless,
Dwight
Now it makes sense..Thanks!
Jake
