5 hours ago, Mujician said:
I have the opportunity to get one of these - can I use it to sew linings on belts and straps, or is it just for small work?
What 29 sub-model is it? Is it mounted on the matching cast iron treadle base, or is it motorized on a pedestal table, or is it just the head? I ask because it takes two hands to guide the work, leaving just your feet to operate the treadle, or an electronic speed controller if it has been motorized.
I use my 29k71 to sew patches over pockets on Bikers' vests and to sew shoe uppers and purse strap tabs. I wouldn't think about using a patcher to sew a straight line longer than a few inches unless you first gouge a stitching channel into the top layer. Keeping the claw foot from moving sideways can be done by tightening a thumbscrew that goes into the front of the revolving head housing.
You really should not waste your time with a patcher unless you do shoe or purse repairs or sewing for Bikers. The bobbins are tiny and the thread handling capacity usually maxes out at T90. Finally, the maximum stitch length of a like new machine is only 5 stitches per inch, into 8 ounces of leather. The thicker the work, the shorter the stitches. As these machines wear out the stitch length gets smaller and smaller. I have encountered patchers that could only sew 8 per inch into thin shoe upper leather.
Posted IMHO, by Wiz
  • 5 years later...
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
I JUST PURCHASED A SINGER 29K60.  I HAVE RESEARCHED (THAT WAS INTERESTING) FOR INFORMATION ON THE CORRECT NEEDLE FOR THIS MACHINE AND WHAT THE  PROPER THREAD WOULD BE FOR 8/9 OZ. LEATHER.  I COME UP WITH AT 92 OR 138 BONDED NYLON FOR THE THREAD AND 123 HEAVY DUTY NEEDLE.  IF SOMEONE WOULD CLARIFY THIS OR POINT ME IN THE RIGHT DIRECTION I WOULD TRUELY APPRECIATE IT.  THANK YOU
  • 1 year later...
I am looking at buying a 29K73
l am in the process of looking for sewing needles
l turned the crank. It didn’t move far. Oops. It is quite gummy.
machine comes with the stand. It is a treadle
It uses system 135x16 in  leather points and system 135x17 in round points.
Posted IMHO, by Wiz
clean the machine up first and oil  it good  to see how it turns,\.
Glenn
