Members Wolf Tracker Posted September 3, 2012 Members Report Posted September 3, 2012 I am hoping someone can help me out here. I recently bought a Singer 111w155 and I am trying to replace the timing/arm shaft connection belt. I followed the instructions in the Singer manual by removing the screw in back of the machine near the balance wheel to remove the arm shaft bushing. My problem is the bushing won't move. I'm not sure if there is more to be done or if the bushing is stuck. Any info on this would be helpful. Also I did find this site while searching for answers to my problems. I don't think it has been posted on this forum but if it has I apologize for the repeat. It does have a lot of info on old Singers. It is http://designer-entrepreneurs.com/blog/illustrations/sewing_machine_adjustment_survival.pdf. Lastly I would also like to thank Bob from Toledo Sewing and would highly recommend him for your sewing needs. Not only did he take time to help me with what I needed but his shipping was lightning fast. Quote
Members Gregg From Keystone Sewing Posted September 4, 2012 Members Report Posted September 4, 2012 I am hoping someone can help me out here. I recently bought a Singer 111w155 and I am trying to replace the timing/arm shaft connection belt. I followed the instructions in the Singer manual by removing the screw in back of the machine near the balance wheel to remove the arm shaft bushing. My problem is the bushing won't move. I'm not sure if there is more to be done or if the bushing is stuck. Any info on this would be helpful. Also I did find this site while searching for answers to my problems. I don't think it has been posted on this forum but if it has I apologize for the repeat. It does have a lot of info on old Singers. It is http://designer-entr...nt_survival.pdf. Lastly I would also like to thank Bob from Toledo Sewing and would highly recommend him for your sewing needs. Not only did he take time to help me with what I needed but his shipping was lightning fast. Wolf, If Bob is doing a good job for you, and I'm sure he is, contact him, he will know what to send out for you immediately. Quote
CowboyBob Posted September 4, 2012 Report Posted September 4, 2012 Wolf, If Bob is doing a good job for you, and I'm sure he is, contact him, he will know what to send out for you immediately. Richard, You need to loosen the 2-screws on the collar that you get to through the top plate. Also make sure you sand down any burrs on the shaft were the grooves are for the handwheel screws or it won't slide off. Let me know if you need anymore help. Bob Quote
Members Wolf Tracker Posted September 4, 2012 Author Members Report Posted September 4, 2012 Thanks for the picture and info. i will give it a try tonight. Rich Quote
