Members 15mules Posted October 21, 2012 Members Report Posted October 21, 2012 The press looks identical to the one Grizzly sells here in the U.S. Grizzly is an importer of woodworking and metalworking equipment and have internet sells as well as 3 stores in the U.S. I just happen to live close to the one in Springfield Missouri, so I save the shipping cost (but have to pay tax ??) I am planning on getting one and making some modifications so I can use it as a clicker and also for other embosing needs with large dies. I fiqure with the guage a person should be able to closely duplicate the impressions. Quote
Members whiteeugene Posted January 22, 2013 Members Report Posted January 22, 2013 Paul: You can do the same thing with the Weaver bench top press. I changed out the 6-ton jack that came with it and put on an air-over-hydraulic 12-ton jack. The jack was ~$40 at Harbor Freight. Hi K-man how does the air-over-hydraulis work been thinking of doing the same but not sure if it works on the up strock as well as the down stroke. How do you control the amount of presher do you use a gage, also how do you release the preasher do you have to still twest the little nob on the jack? I would like to have something that I can control with my feet that away I dont have to take my hands off the project I find that when I have a large piece of leather it hepls to have someone else turn the nob and pump the handle. Quote
Members JJs Leatherworks Posted January 22, 2013 Members Report Posted January 22, 2013 Whiteeugene - I have a 30 ton version of the air/hydraulic press in my mechanical repair shop. The air pressure just runs an air powered motor on the hydraulic pump (hand lever can be used if desired). Once there is any backpressure on the cylinder, the attached gauge shows the amount of pressure exerted. To release, yes there is a small knob that is turned by hand and the cylinder will retract by 'spring' pressure. With a little extra hose, the air control could easily be converted to a foot control, right now it is just a hand controlled valve, much like you would have on a compressed air blow gun. The release likely couldn't be modified. Hope this helps. JJ Quote
Members whiteeugene Posted January 23, 2013 Members Report Posted January 23, 2013 Whiteeugene - I have a 30 ton version of the air/hydraulic press in my mechanical repair shop. The air pressure just runs an air powered motor on the hydraulic pump (hand lever can be used if desired). Once there is any backpressure on the cylinder, the attached gauge shows the amount of pressure exerted. To release, yes there is a small knob that is turned by hand and the cylinder will retract by 'spring' pressure. With a little extra hose, the air control could easily be converted to a foot control, right now it is just a hand controlled valve, much like you would have on a compressed air blow gun. The release likely couldn't be modified. Hope this helps. JJ Thanks JJ I sent you a response to your also Thanks Doug Quote
Members billymac814 Posted January 23, 2013 Members Report Posted January 23, 2013 I have a similar setup but with a harbor freight press, I too swapped out the jack for the air version. Its by no means quick but it sure saves pumping. The key is to only release it enough to get the die and leather out and insert the next piece then it only takes a few seconds. Sure beats cutting. Quote www.mccabescustomleather.com
Members K-Man Posted January 23, 2013 Members Report Posted January 23, 2013 Hi K-man how does the air-over-hydraulis work been thinking of doing the same but not sure if it works on the up strock as well as the down stroke. How do you control the amount of presher do you use a gage, also how do you release the preasher do you have to still twest the little nob on the jack? I would like to have something that I can control with my feet that away I dont have to take my hands off the project I find that when I have a large piece of leather it hepls to have someone else turn the nob and pump the handle. It has worked great. I've been using this configuration for approximately 5 years now. The jack does not have a dial showing the pressure. The air action is engaged with a "switch" (for lack of a better description) that is depressed and located on a portion of the air hose. The pressure is released with the traditional small button/knob on the cylinder. As JJs Leatherworks mentioned, you could convert the switch to a foot pedal with little effort. Quote
Members whiteeugene Posted January 23, 2013 Members Report Posted January 23, 2013 I have a similar setup but with a harbor freight press, I too swapped out the jack for the air version. Its by no means quick but it sure saves pumping. The key is to only release it enough to get the die and leather out and insert the next piece then it only takes a few seconds. Sure beats cutting. Thanks Billymack hows the weather in Altoona this time of year I used to go to the national guard armory once in a while in the 80's when I was stationed at Indian town gap. Quote
Members whiteeugene Posted January 23, 2013 Members Report Posted January 23, 2013 It has worked great. I've been using this configuration for approximately 5 years now. The jack does not have a dial showing the pressure. The air action is engaged with a "switch" (for lack of a better description) that is depressed and located on a portion of the air hose. The pressure is released with the traditional small button/knob on the cylinder. As JJs Leatherworks mentioned, you could convert the switch to a foot pedal with little effort. Thanks K-man I have a foot pedal on my sand blaster its from harbor Freight also. The current press I have has a pump to the side and a slave cylinder attached to the top of the press. It works great for small items but if I want to punch several things out of a hide it's kind of hard to hold onto the leather and die and pump the handle at the same time. Quote
Members billymac814 Posted January 23, 2013 Members Report Posted January 23, 2013 (edited) Its pretty cold right now in Altoona. Freezing cold actually. Luckily my shop is a balmy 70. Here's a picture of my set up. I cut the ram off and attached a 1/2" plate. It serves double duty as I use it for clicking and molding, I just replace the gum rubber with another 1/2" thick piece of steel. A foot control would be nice, unfortunately my hose isn't long enough so I'd have to switch that. Otherwise the control could easily be modified. I have a foot control for my burnisher and my grinder(dremal type but bigger with a flex shaft) As you can see a pair of vise grips makes releasing the pressure quite easy. I also have the button clamped to where its convenient. Edited January 23, 2013 by billymac814 Quote www.mccabescustomleather.com
Members GuardianConcealment Posted January 31, 2013 Members Report Posted January 31, 2013 Anyone have any video of their air assist press? I would love to see that. I have a guy making me a few bench top presses for molding Kydex and might be able to have him do one of them with air jack for my clicker. Thanks for your help Quote Guardian Concealment
