Sixer
Need A Little Help... Shark Skin
It's my first time using shark and second attempt on this belt.
The belt is two layers of 6/7 oz veg tan and will have a layer of shark skin on the outside.
My biggest issue is the belt edges. Once I glue and trim the shark, I'm having a tough time getting figuring out how to get the best edge on the belt. If I take an edger to the belt, the shark skin tends to bunch up and result in a chewed up looking run of shark.
I guess I'm just looking for some advice on how to go about making a shark skin belt. This stuff isn't cheap and I don't really feel like wasting more of it this week ;)
I appreciate any tips or advice!
Cheers,
Eric
Here is what I do, YMMV. I rub a very tiny amount of superglue into the edges of all the exotics I work with. Then after it is dry and hard, I sand it down. Everything blends together beautifully! I use superglue on the edges of exotics, that don't come all the way to the outside edge. This gives it a very nice edge appearance. Hope this helps you out.
I thought there woulld finally be a decent use for super glue!! Thanks for the tip.
belt sander at a 30-ish degree angle to the edge. Works much better than an edger, albeit smellier. Then glycerine bar soap and a burnisher.
I still cant find a piece of shark big enough to get good belt straps out of. For myself I would need one about 53 inches long.
Check Van Amburg Leather
Great idea! I'll give that a try along with Shooter's advice on the belt sander. Thank you, thank you, thank you ;) I obsess over my edges so much... and this was just driving me nuts. Much appreciated guys!
Shooter, I bought this shark from the Ostrich Market a few months ago. It was about 12 sq feet... not sure if I could have gotten a 53" strip out of it, but I bet it would have been close at the right angle ;) Nice stuff!
No problem. I hope it works as well for you as it has for me.
